View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#7621
Ok this discussion leads me to a question.
I am running a TC4 and usually finish top 3 at my track. I have an X-Ray T2 009 with the Exotek lipo chassis. Would I see a benefit if I switch to the X-Ray chassis?
#7622
If you feel that your at your limit with the TC4, then yes it would help as it has more fine tuning options. But if you still are fooling around with the TC4 and havent found that magic set-up yet, then there may not be a need to switch.
I had a coue of Pro-4's that were plenty fast, but i just felt there was nothing left i them tuning wise for me. I purchased a used VBC wildfire and immedeatly gained a couple tenths. Now after some tuning, its getting even better and there is alot left in this car.
#7623
Thanks for that input.
I believe the TC4 has a good set up in it and I like how it drives but I know it is heavy. I think I may lighten it up some and see how it responds before starting all over with my set up.
#7625
I am way over. Closer to 1650.
I just wonder if a perfectly set up TC4 that weighed 1550 and an X-Ray perfectly set up weighing 1550 were driven by the same driver on the same track would one be faster than the other?
#7626
Tamiya TA06 vta setup
We are running a loose roar vta class in the parking lot of my local hobby town USA in spring lake NC. I am using a tamiya TA06 pro and the Novak boss vta combo.
I am chewing up front tires pretty bad, only lasting about 2-3 race weekends before they are beyond what the rules state.
Is this normal wear? I was under the impression tire life would be better than this.
Also, if anyone is using this chassis as well, can you give me a good starting set up, to include gear ratio?
I am running a little behind the fast guys, I don't think my set up is where it needs to be.
I really need a good starting point, I am not great at tuneing yet and I don't want to chase it.
#7627
I wear front tires more than rear. We race on carpet. I got about 4 race days out of my first set.
#7628
#7630
#7631
I run tires for several race days. I can't say exactly but they last a good while on carpet. When they get close to bald I save them for asphalt. Race directors tend to be more lenient on asphalt regarding tread. Especially since tires don't last very long on the tarmac. There's even hints at leniency from the establishment. The tires tend to be a self regulating issue. New ones handle best on carpet. On asphalt bald tires hold up pretty good. Unless they pop.
#7632
Tire wear
I have seen it go both ways as to tire wear.
Were a "pushy" car eats front tires on the asphalt from lack of steering and a car that turns on a dime wearing front tires to about 70% tread on carpet in a month.
The year I ran a lot, (twice a week at club level and twice a month for the Midwest Grand Slam and Hurricane Series), I used a total of 3 sets of tires during the winter from September thru March.
On asphalt, I will run the old carpet tires until they spit the insert out when they split. I don't know of any track that enforces the visible tread rule for asphalt, but maybe some do.
I have noticed as well, if you only change the front tires and not the rears in a set, the wear on the front does go up as well.
#7634
I probably have too much front traction.
What are the general setting for toe, shock oils and ride height?
Those should transfer between chassis.
