View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#4711
I've got a clarification question about tires. We all know the part numbers for the allowed tires per USVTA rules. Locally, we've had some debate regarding the legality of adding tape or other materials to the inside of the tire to effectively "belt" the tire to prevent ballooning. I think this is outside the spirit of the class so I don't do it, but that's just my personal opinion.
Has the USVTA ever issued any kind of official statement regarding this?
Thanks,
Tommy
Thanks,
Tommy
Tire & Wheel Specifications:
The only tires allowed are HPI tire part #4793 "front" and #4797 "rear", using stock tire inserts provided with tire and any HPI Vintage wheels designed to fit these tires. All other tires and/or part numbers are illegal. Wheels and tires designated as "front" must be used as front tires/wheels, "rear" wheels/tires must used as rears. Five or Eight spoke wheels available in various colors. 0mm offset front wheels and 6mm offset rear wheels are intended for 26mm width fronts and 31mm width rear tires. 8-spoke Vintage wheels from #3805 through #3814, 5-spoke Vintage wheels from #3815 through #3822 and Vintage stock car wheels from #3854 through #3860, Vintage Wheel CC Type #33472 and #33473, Vintage Wheel DTP Type #33474 and #33475 are all legal wheels.
Grinding of tire tread is NOT permitted. Sanding of mold seam to remove seam is allowed. HPI Vintage Slicks and HPI Vintage Performance Tires are not allowed. Tire traction compounds are at the discretion of the track. No other altering, changing or softening of the tire is allowed. All decisions of the race promoter or track owner are final. No "double stuffing" of foam inserts allowed—only single stock vintage tire inserts are allowed.
#4713
Thanks,
Tommy
Thanks,
Tommy
#4714
Would or Does "Belting" the tire cause the tire to wear more evenly, and prolong the life of the tires? If so, why would you ban something that ultimately could be a cost savings that can be done very cost effectively?
Why wouldn't instead this practice be embraced, and put up a "How To" to inform people how to do it?
#4715
Here we go...
I think there is already a big difference in skill and ability between racers when it comes to something like mounting tires. With some guys, no matter how much instruction and help they receive, and no matter how many Youtube instructional videos they watch, they still cannot properly mount a tire. It would be wonderful if HP offered these in a pre-mount to help them out, but they don't.
So now if you add belting, some will figure out secret formula tapes and taping methods to gain advantages that will leave average drivers scratching their heads even more than they do now at how the "fast guys" are so fast. Ultimately, this is a big turn off in any class. A spec class is meant to keep things close, and using equipment out-of-the package as it was intended to be used helps to keep it close. The more variables introduced, the wider the gap between the front to back of the class. This is meant to be a drivers class where everything equipment-wise doesn't matter so much and allowing modifications to tires is slippery slope.
#4716
Need help with setting up TC4 running VTA and car is loose as a goose. thanks
#4717
http://www.teamassociated.com/pdf/ca..._edit_2007.pdf
After seeing what you are running we can make some suggestions.
Also let us know if you are running on asphalt or carpet and what traction compound you are using.
#4718
...me personally, I can't say I CAN'T properly mount a touring tire, but I can say I HATE mounting Touring Tires, and also wish HPI offered these "ProMounted" on at the very least ONE decent set of 8 spoke silver wheels... (I've had a NEW set of tires floating around for 6 months that I really am dreading mounting - all I've ever used on a VTA car is someone else's 1/2 worn out take offs. (that usually look like the alignment was way off and worn bad on the edges)
#4719
Hpi does sell VTA tires pre-mounted, but only the fronts. They come with some of their rtr kits. You will see people selling them online.
As far as even tire wear, that is more a setup issue combined with traction compound being used. Black can paragon will soften the tire and make them balloon. Other compounds like SXT or jack the gripper don't seem to overly soften the tire. If the outside of a vta is ballooning, it is usually from too much negative camber.
Even if old vta tires expand a bit through their life, you should be able to get fairly even tread wear on carpet. Asphalt or concrete can be hard on vta tires with a poorly setup car, but you can still get even tread wear across the tire.
#4721
A friend of mine and myself are looking to get into the VTA style of racing and while he's dead set on getting a tc4 club racer, im teatering between a tc4 cr and a used Tamiya 416x that ive seen on the for sale thread here on rc tech. is there any advantage to one over the other?
#4723
I owed a TC4 when it first came out and then changed to a Tamiya 415. From then on I was hooked on Tamiya. Personally I think because your friend is getting a TC4 you would be better off at this point running the same car as him.
For anyone else interested: http://www.rctech.net/forum/r-c-item...o-chassis.html
Last edited by Travis S; 05-26-2013 at 07:51 PM. Reason: Figured I should add a link to my 416x for sale...
#4724
Having raced neither. I think I would prefer the Tamiya, but you would have to scavenge a little to replace the breakables. I am running a Yokomo MR4 TC SD SSG which is from the same era as the TC3. Just a little newer and a little more refined shafty.
If you just want to race and want a good no frills chassis that you can get parts and advice for then the TC4 will be fine.
#4725
We had our "OUTLAW" VTA Enduro race this past Sunday at Cal R/C Racway in Southern CA.
There were only 8 teams (had hoped for a full 10 car field) but I believe that was 31 different drivers (Most teams used 4, I think one only used 3)
The 1000 lap event took right at 4 Hours, and most teams elected to make around 8-10 pit stops.
The Driver Skill Level was across the board from a team (OURS) of mostly Oval Pan Car guys, to some of R/C Racings ELITE (Including former WORLD CHAMPION Tony Neisinger driving on the TEAM ASSOCIATED team.)
The rules for this race allowed OPEN "Roar Legal" 21.5 motors, upto 5800 mAh "Roar Legal" Batteries, BLINKY ESCs, and limited to a total of 10 Tires (HPI Vintage Treaded or Slicks) Most teams opted for the Treaded, but I believe 2 teams went with SLICK fronts and Treaded Rears. (Including the WINNING Team, that did the WHOLE Race on One set of tires (Which FELL APART on the Victory Lap)
I have to say, this race was one of THE MOST FUN Events I've ever been a part of - and the racers "Sportsmanship" was 2nd to none.
for pics, results or other info on the OUTLAW VTA guys in SoCal - check out their thread in the CA Section -
http://www.rctech.net/forum/californ...ance-race.html
and here's a edited for time video
+ YouTube Video | |
