View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#4621
there is some cheating going on in vta at my local track vta car driving like touring cars with throttle turn down wtf is going on here what are these cheater doing to these 25.5 motors to get them that fast ? i hear that they are changing the stator and rotor not stock 25.5
#4623
As far as cheating in VTA, what speed controls are the "cheater" cars using? If they aren't using a USVTA legal speed control, there are a number of ways they could be gaining advantages. Before the current USVTA rules, I've caught a few people running a midly boosted car (one even claimed they changed to blinky but the programming on their speed control didn't take).
I've raced enought VTA to know that some people will just get everything right and their cars will just be faster than almost everyone else. By faster, I mean lap times and not necessarily straight speeds. A VTA car geared fairly tall will gradually pull away/catch up compared to other cars on a long straight. However, no VTA car should look like it is shifting into a 2nd gear on a long straight. I would suspect a car like that is using a tuning rotor, which IS illegal per USVTA rules.
#4624
There is a big lap time spread among VTA racers at my local track. However, there is very little straightaway speed difference.
Why?
Setup: The faster drivers work on their car setup, get their cars to stick hard and steer hard.
Maintenance: The faster drivers check their bearings to make sure they are free and smooth, their shocks are filled right, suspension moved freely, etc....
Driving: VTA cars are really slow. If your car is setup right and maintained right you have to put it in the right place on the track to maintain momentum and corner speed to net the best lap times.
VTA is all about precision in your car setup and in driving. As racers get more serious and faster racers start running VTA it is becoming a very challenging class.
Why?
#4625
+1 on what Adrian said. I spent countless hours on mine working on the shocks, suspension, diffs, and any other corner I could find to get mine to run at its optimum and still have not gotten all out of it I can. I don"t have much straight speed to speak of compared to the others I race with but gain a ton of speed in the corners and tight sections of the track. Adrian has seen me spend a whole race night rebuilding every corner on the car to squeck out one more tenth so maybe you need to do some more homework before blasting guys that worked hard to get theirs fast.
#4627
I so agree: I constantly get acussed of cheating as my lap times and race times are much faster than most. It is due to tuning and the nut behind the wheel.
my droop is almost the same as my mod car, it is my roll centers that are FAR different, I raise the lower arms
#4628
Locally, we have very good parity regarding top speeds in VTA. Of course, lap times will vary quite a bit, but most everyone has very similar top speeds and it's very evident because we typically have a quite long straightaway. It's not often a car is significantly faster, but when they are, it's pretty obvious.
#4630
#4631
Here's a thought:
Post the name of the track and the names of people who you think are cheating and I'll bet that by the end of one week you have most of them waiting for you out side of the track so they can explain to you how they are "cheating". They may choose explain one at a time or all together. All together would be quicker.
After you get out of the hospital you might want to take up collecting Hello Kitty fan swag or something on that level.
Just a note:
If this track you go to is running USVTA rules, then the stators are color coded and the modded rotors have are marked to identify them as well (go to NOVAK's web site and see for yourself) because only NOVAK motors are legal.
Derp.
http://teamnovak.com/products/index....x&cPath=98_116
http://teamnovak.com/products/index....x&cPath=98_111
Just a note:
Derp.
#4632
Personally I think that if it is so obvious that people are cheating, then your local track should be running their tech program a little better. However, I can't stress enough how important chassis set up is. Tenths of seconds add up in a 5-8 minute race. If the track is small enough, it could result in your being a lap down in no time.
#4633
I meant to reply to this the other day, too. If you opt for the chrome or flat aluminum looking wheels, make sure you remove any of the chrome or coating that is in the glue or lip seating area. I bought a set of chrome wheels and tires pre-mounted from a local racer. He did NOT sand away the chrome. Once a tire pulls away from the rim it will pull the plating from the wheel and it's virtually impossible to get them to adhere properly.
#4635
