FW06 Center shaft
Are you sure they are different lenghts? I have FW05T+'s (uses the same part).. different design, (F/R) but they are the same lenght. As for the VS024, they are both the same... and fit.
Strange
I have a few of these cars, and are planning to convert them to FW-06... The chassis and drive line are the same..(according to the part numbers)... was sure the old plastic shafts were the same... (have to find them)
The VS-024 is 59mm
I have an FW-05R NIB... just checked... they are both the same... VS-024
The VS-024 is 59mm
The VS-024 is 59mm
The VS-024 is 59mm
BTW. I also want to convert the engine. Do you have engine mount?? Is that VS065 fit??
What's your setup for this car?? My local track got a lots curves. I found sometime the car just over steering and spin. Still can't fingure out the best setup. And also can't find many setup info for this car in forums.
lots of new parts for FW-05
If anyone is interested in re-newing this car, I have a car, KYOSHO 1/10 two draw carry bag, new chassis, ton of brand new stock KYOSHO parts, 2 bodies, etc. need to make room so must be getting rid of this lot for $100 or best offer. PM me your e mail and I'll send you pictures if interested.
