Check out the new BSR web site!
Check the new BSR web site!
John at John's Bsr tires has a new web site. These are the same tires Stephen Sobottka used to win the US indoor champs! If you are looking for a great alternitive in on road or oval racing tires check out BSR!
http://www.bsr-racing.com/
-Monti-
-Monti-
BSR tires are the best. I found this out at the USTC race #4 last year at Trackside. I tried a set of BSR's and gained .1-.2 sec per lap over the jacos I was running. That got me hooked.
BSR carries 1/12th on-road, and electric touring in all the popular compounds as well as 1/10th scale oval (foam and capped) and nitro touring tires.
Good combos to start with from BSR are purple/gray or purple-orange/gray for 12th and Dbl Pink (XX Pink)/orange and Dbl pink for Touring. If you have any questions feel free to ask.
Originally posted by JDXray
I have recently used the BSR foams for my Xray, and they are NICE! The rim is alot tougher than the jaco ones. Nice Website too.
site lookes great tires look and drive even better the best wheel on the market!!!!
How does the wheel stiffness compare to the Jacos and TRC's? Is the foam the same foam as the Jacos (as the Parmas use the same foam as TRCs)? Also how wide is the wheel, and is there any offset built into it? I like the Parmas because they are true 28mm and are offset so they don't rub on the shock ends on certain cars. Jacos are 29mm wide.
Josh
Josh
