eXpress Motorsports
Last I was told this coming week. After we recive motors it takes 1 day to go thru our process then all will be shipped......
Tag,
I picked up a Thunder Power 610C based on your recommendations. How do I make a balance plug to work with the charger to use with Trinity and Orion Lipo packs? What plugs should I get and what orientation would I solder the wires. Any help would be appreciated. Also, can't wait until AB-Charles gets in the lipo packs and motors from you again.
Thanks,
Ty
Thanks,
Ty
Tag,
Thanks,
Ty
Thanks,
Ty
First get a 2s Male plug with the 2 black wires and 1 red wire attached. There will be 3 wires coming from it 2 black and 1 red. Take the outer red +and black- and connect (Tap them inline)them to out going power leads that connect to Lipo. Take the last black wire and extend with some old servo wire and solder the 2mm plug onto that . When balancing pack just plug into the charger ballance junction. I only ballance every 2 weeks but NOT for a race, I only ballance for a practice run......
Here is sample link to get you a better idea.....
brushless 17.5
John,
Thanks for the wiring info for the 12th scale. I am looking forward to running the car at the Gate again when I get some time. I have a 74 tooth as well as a 76 tooth spur gear for the car as well as 47-55 tooth pinions from PRS. Most people tell me to start at about 50-76.
Thanks again for the info,
Robert Shuchman
Robert Shuchman
Trader Rating: 51 (100%+)
Tag ygpm
yo john
john uhpm
All mail returned...
I just added some fresh IP3800 Lipos to web. These are fresh from cycling all last night. Some great packs get them while they last......
Both.. But out of stock on SMC right now...
Tag,
Sent you a PM about a motor the other day. Did you get it?
Tag, You have mail.
Hey all..
For those looking for shirts. Please send size and shirt style request to me at [email protected] and use Shirt in title line. Please include color Gray or Blue in color,Size and short or long sleeve. We will be have special request in this shippment only ,all extras will be long sleeve gray....
O.K.
Shirt order sent in.....
And a motor and battery one as well
The Classic awaits!
The Classic awaits!
ok so tell me whats not right....Im running a t2 008 with your 17.5 and im running 57mm tires with a 92/47 combo at the raceway in beaver i was hitting 190 degrees, am i figuring my fdr and rollout wrong ? where should i be in gearing for cleveland this weekend
I would say your over geared. I know Your about 3 teeth higher than where I plan to start. Try starting at 45 pinion more toward 49mm for the Gate and about 44 pinion at Beaver. Also be very sure chassie is free not pushing at all as that will increase heat. Hope this helps some......
