VBC new 1/10 touring car, Wildfire. >
Old 08-11-2012, 04:59 PM
  #316
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default Yes
Originally Posted by 303slowdown
This is the same on almost every car when running blinky. I have 417, xray, robitronic, all the same with the motor screws. What you do is tighten the front screw to set mesh then take top deck off and pull layshaft up to tighten other screw.
Agree most cars running 17.5 will have this.
Keep in mind once this set correctly you won't changed in often....a wrench with a ball end is your friend.
olhipster1 is offline
Old 08-11-2012, 05:19 PM
  #317
seth556's Avatar
Trader Rating: 43 (100%+)
So that's solved, what about the pinion hitting the top deck situation?
EDIT: Just did some sanding and everything fits now, just wasn't sure if this is correct protocol in onroad or not.
seth556 is offline
Old 08-11-2012, 06:26 PM
  #318
schreff's Avatar
Originally Posted by MikeXray
I love reading sponsored guys first run with a new car posts, this one did not disappoint either car is Lethal
Lethal = it broke a wall instead of the car and peeled an entire rear suspension off a TC6.1.
schreff is offline
Old 08-11-2012, 07:53 PM
  #319
The Teacher's Avatar
Trader Rating: 62 (100%+)
schreff, What tires were you on? Also, do you think you will make it down to MRH this indoor season? Would like to see that car in capable hands on the rug...
The Teacher is offline
Old 08-11-2012, 07:56 PM
  #320
schreff's Avatar
Teach, our track tires are Solaris Hard or Jaco Blues. I was running Solaris Hard tires.
I'm sure I'll be down to MRH at some point. Not sure when. The guys really want me to go this coming weekend, but I plan to go to a Nitro Offroad race that Saturday.
Very soon though.
schreff is offline
Old 08-11-2012, 08:57 PM
  #321
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Very soon though.
Well I guess you guys didn't get rain. It was raining in the morning when I left the house so ended up going to MRH.
Car was pretty good but I would like it a little more locked down in the rear of the car. I also put an Xray hard bumper on after I broke a front steering knuckle but after that was good all day long.
For me I have to say I have never had a touring car steer so hard out of the box with a spool. I really like my car mellow in the front end on carpet so I have some more work to do but overall after a 5 year layoff didn't do bad.
3rd round was on a A main run but had some trouble. Overall I just need more time to get use to carpet and how it changes as the traction comes up. Need to take out the drag brake as I think that makes me too loose off power in the some of the corners if I leave off too much. I don't have a ton in but I will try less next time I run carpet. Lots of stuff to try over the upcoming weeks so I can see if I can be more competitive on the rug.
wyd is offline
Old 08-11-2012, 09:22 PM
  #322
Odin544's Avatar
Trader Rating: 93 (100%+)
Wyd are you running mod? Pretty sure I'l be buying this car for onroad season. I'll be running on carpet only in 17.5 blinky class.
Odin544 is offline
Old 08-12-2012, 07:18 AM
  #323
wyd
Tech Legend
wyd's Avatar
I'm running 17.5 blinky on carpet as well. I'm still working on a comfortable setup but it will take me a few more weeks til I get all my springs I have on order and just overall get more comfortable driving a touring car again.
wyd is offline
Old 08-13-2012, 11:44 AM
  #324
Trader Rating: 39 (100%+)
Sounds like I should get one of these cars. I like things that turn. A LOT!!!!
Jamie Hanson is offline
Old 08-13-2012, 07:56 PM
  #325
wyd
Tech Legend
wyd's Avatar
The stock setup does steer on carpet for sure. They have the front arms spaced back 3mm out of the 4mm it can move total. The rear arms are 3mm back so the combination of short front arm setup and longer rear arm setu does give the car some steering.
wyd is offline
Old 08-14-2012, 03:59 AM
  #326
Problem with the box stock arm spacing is that the car seems to dump over to hard in the front.
Old 08-14-2012, 06:01 PM
  #327
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
Very soon though.
you need to show up at jackson
Warren Weaver is offline
Old 08-15-2012, 03:23 PM
  #328
GMartinez's Avatar
Trader Rating: 91 (100%+)
That is still not going to solve it
I tried that & you have to sand it down a bit Im running an xray gear 96 with a trinity 50 pinion & after trying that it rubbed sanded it down a tad & no problem
GMartinez is offline
Old 08-15-2012, 09:33 PM
  #329
on the VBC Racing site (one the Quickest to navigate sites i've seen in ages!) the new Dynamic belts are these kevlar?
i know i read earlier on other belts to use.
just curious on these?
ems
Eric Summers is offline
Old 08-15-2012, 09:37 PM
  #330
Trader Rating: 19 (100%+)
ems
They are supposed to be more durable and last longer. Especially in mod. I just finished my own car and will be testing tomorrow with the stock belts and then change them to the other belts (the type r's) to test. But i may just wait to see how long the stock belts last.
-Randy
COLD AS ICE is offline
