OS 12 TzR
#1007
I'd suggest you give the engine break-in with the same fuel your going to run the engine. But this is just me. Stay with the stock plug, and if you need spares. Buy them at rc-toro.com (6 pieces for $28) while OS glow plugs alone cost up to $10-12 each. I used Cyrul's break-in procedure. I did use a heat gun on the engine to expand the sleeve. Only problem I had during the procedure, was the engine reaching high RPM's when I re-fueled. For this, I closed the throttle to idle, refueled, then back to full throttle. Had to re-start the engine sometimes due to flame outs.
#1009
Originally Posted by HarKonnenD
So is it preshimmed for 30% or how many more shims will I have to add? What mm are they?
#1010
Originally Posted by rc_alan
The TZ-12 will run great with the RB & Nova pipes...
Cheers
#1011
This is probably not the right thread. But, I could not see one for it. I recently purchased a OS .18TZ from rc-toro. I need to get a pipe and header for it. It is intended to put into a V1RRR. Any suggestions are welcome!!!
#1013
so ,what’s the feedback on the ZAC modified TZ3s?
good?
- more bottom end? Top end? Run time?
good?
#1014
I'm currently running 20% fuel for this motor. if I decided to run 30% fuel do I need to add an extra shim to this motor
#1015
#1016
good?
good?
The ZAC TZ was also apparently used by a couple of guys who finished top 10 at the recent Pre-Worlds
Cheers
#1017
i have had the 5 port and after seeing andys car going,i know what i'll be getting next
#1019
Originally Posted by mrgsr
andy how about a drag race with my mod tz
#1020
hey...I was just wondering what a good pipe is for the OS TZ 5 port?
Thanks in advance.
Thanks in advance.
