Exotek f1Ultra F103 conversion >
Old 03-12-2012, 09:30 PM
hi-tech-redneck's Avatar
here are a few pic's of the build so far!......i work for at&t here in california so i think i will go with the at&t williams f1 car,gotta get some decals made!
Attached Thumbnails Exotek f1Ultra F103 conversion-wp_000369.jpg   Exotek f1Ultra F103 conversion-wp_000373.jpg   Exotek f1Ultra F103 conversion-wp_000374.jpg   Exotek f1Ultra F103 conversion-wp_000375.jpg
hi-tech-redneck is offline
Old 03-12-2012, 09:36 PM
note if you use the shorty pack from exotech you will need to shim for the hight of the pack! suckers tall!
Old 03-12-2012, 11:38 PM
electronic's in....binded&setup speedo,need to get a ball park figure for gearing and plan out paint and decals
Attached Thumbnails Exotek f1Ultra F103 conversion-wp_000377.jpg   Exotek f1Ultra F103 conversion-wp_000378.jpg   Exotek f1Ultra F103 conversion-wp_000379.jpg
Old 03-13-2012, 04:27 AM
tudor_47's Avatar
looking really good!
I think the kit solves alot of the electronics installation problems of F1 cars.... plenty of space in front o battery.
keep them pictures coming
tudor_47 is offline
Old 03-15-2012, 10:34 PM
  #20
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi, on this step you want to just use a 1mm spacer on the bottom of the post as shown in 17 [E] of the instructions. This should get the hight just right so that the carbon strap just sits close enough to keep the lipo in place Spacers on the bottom also makes it easier to remove the top carbon strap for battery removal- less hardware to deal with.
MikeR is offline
Old 03-26-2012, 05:08 PM
  #21
had a guy make the decals for me,my version of the williams at&t exotech f-103 club racer! won't win any concours but should be very competitive!
Attached Thumbnails Exotek f1Ultra F103 conversion-wp_000395.jpg   Exotek f1Ultra F103 conversion-wp_000391.jpg   Exotek f1Ultra F103 conversion-wp_000394.jpg
Old 03-30-2012, 05:06 PM
  #22
Trader Rating: 12 (100%+)
Looking to grab this kit but haven't got anything to fit it to yet. I'm thinking would it be better to use this kit with a:
f103 and getting some hopups (alloy motor mount etc.)
f104w gp (which seems to have most hopups covered)
I guess what I really want to know though is whether this kit would be better with a f103 or f104 rear end.
John
J-PaP is offline
Old 03-30-2012, 07:12 PM
  #23
liljohn1064's Avatar
Trader Rating: 17 (100%+)
John
Its the short wheelbase. If you have an F104W, I'd get the F1R. I have a couple highly modified F103s and this is the one I'm looking at.
liljohn1064 is offline
Old 03-31-2012, 04:33 AM
  #24
Think you may have misunderstood what I am asking. I want to know whether the f1ultra is better with a f104 or f103 rear end. According to the exotek website it can fit either.
I don't have a f103 or f104w yet. I am going to buy one of the two to build up this car.
F1R isn't an option for this build as I am intending to use that with my f104 x1.
J-PaP is offline
Old 04-01-2012, 10:51 PM
  #25
Anyone able to answer the question?
John
J-PaP is offline
Old 04-01-2012, 11:09 PM
  #26
MikeR's Avatar
Hi, I would recommend a 103 rear pod. 103 pod lets you get a lower ride height if you are running small diameter foams. Some 103 rubber tires have a slightly smaller diameter (then 104 tires) so you want the lower ride height of the 103 pod any ways.
Note F104W is just a f103 when it comes to the tires.
MikeR is offline
Old 04-01-2012, 11:11 PM
  #27
Trader Rating: 21 (100%+)
John
The F103/F104 rear pods are nearly identical. The rear pod on the F103 positions the rear axle a few mm further back (sorry, haven't measured. eyeballing it, looks to be about 1-2mm). In other words, your wheelbase would be SLIGHTLY longer with the F103 pod. The ride height is also angled lower on the 103 pod, but the adjustment range is pretty broad using the included spacers.
The shock tower mount on the front of the pod will be slightly different as well, but the exotek kit should have mounting positions for either.
Good luck!
silencery is offline
Old 04-02-2012, 01:44 AM
  #28
Thanks for the information. Is there a way to use a f104 rear diff with the f103 pod (and can you still use f103 rear wheels)
J-PaP is offline
Old 04-02-2012, 04:12 AM
  #29
texastc's Avatar
Yes. They are interchangeable.
texastc is offline
Old 04-02-2012, 05:26 AM
  #30
MrUnlimited's Avatar
Here is nice motorpod for the F103: http://www.ebay.com/itm/GPM-ALLOY-AL...ht_1468wt_1163
MrUnlimited is offline
