Team Durango DEST210R thread >
Like Tree6Likes
Old 02-03-2013, 11:32 PM
  #511
xrayrc's Avatar
Trader Rating: 63 (100%+)
Originally Posted by zipperfoot
Thinking of trying 2 hole pistons, rm3, with a shorty pack. Anyone have any experience using 2 hole pistons on an outdoor dirt track? If so what springs and oil did you use?
I'm running 1.6 front 1.7 rear 2-hole and loving it!
30-25 losi shock oil
Purple front spring, light red rear
xrayrc is offline
Old 02-05-2013, 05:13 PM
  #512
Bigrigger's Avatar
So, I've just built my ST and raced the other day with great results but was a bit perplexed as I wasn't able to get great steering throw without the wheels rubbing on the front side of the suspension arm and camber link ball cup as well. Just wondering if anyone else has this problem and come up with a solution. I'm not that keen on dremelling the arm for fear of weakening it but the wheel is rubbing so bad that it is creating a groove on its own.
Bigrigger is offline
Old 02-05-2013, 06:28 PM
  #513
Trader Rating: 19 (100%+)
Are you not getting full throw when the truck is at full droop? At ride height it should cycle just fine, but it can rub a bit with the front arms at full droop. Technically this shouldn't matter- if you're at full droop the truck is most likely in the air and full lock doesn't do much there. But, I dremeled the arms on my SC with no breakages since it was new back in August. I wouldn't recommend taking half the material away, but a little bit for clearance if it bothers you won't hurt- the arms are pretty darn stout.
Jonny5 is offline
Old 02-06-2013, 12:44 AM
  #514
Bigrigger's Avatar
I'm not getting full throw at every point of the suspension compression. I have my EPA dialled down to where it just starts to rub and the inside wheel still has more travel to go if it wasn't for the outside tire rubbing. A bit of a strange design. I definitely feel the truck could gain more steering if it wasn't for this. Otherwise the truck is killer. It's in mm4 for indoor carpet right now and man does it feel balanced. I guess it's time to break out the dremel.
Old 02-07-2013, 11:32 AM
  #515
Mini8 Menace's Avatar
Default Got it fixed and their dialed now
Originally Posted by BT00561
I havent had any issues with my shock either. Might wanna go through them and see if something is missing.
You guys were right I love my shocks on my dex408 never had a problem after taking everything apart I realized I didn't have the rubber shock stoppers on them "dumb" but after doing this I'm getting great results also my piston had backed out so I put a little thread lock on the screws and after 2 weeks of running my truck is dialed
Mini8 Menace is offline
Old 02-08-2013, 09:36 PM
  #516
Trader Rating: 152 (100%+)
*New* DE Racing Trinidad Yellow Wheels $5 a pair plus shipping. I have over 25 new pairs. I sold my truck and bought too much wheels. I'll cover shipping if you buy 4 pairs.
bluebon88 is offline
Old 02-09-2013, 05:41 AM
  #517
Potoczak's Avatar
Trader Rating: 120 (100%+)
Please pm me if interested in aluminum c hubs!!
Potoczak is offline
Old 02-09-2013, 09:40 AM
  #518
Trader Rating: 29 (100%+)
I have been reading some stuff, and It seems that alot of people run the MM set up on high grip tracks. But does anyone run a MM set up on a Loomy/dusty track?
BT00561 is offline
Old 02-09-2013, 03:21 PM
  #519
Bigrigger's Avatar
I run the DEX210 in the summer on dusty/loomy tracks and in MM the rear end just refuses to stay when accelerating out of corners and the car has too much steering which does nothing to prevent the rear from coming around. The extra weight behind the rear wheels really helps balance the drivability of the car. I'm sure the same would translate to the truck as most are using roughly the same setup as their cars.
Old 02-10-2013, 04:16 PM
  #520
Jadair43's Avatar
I saw some posts earlier about different bodies. Has anybody tried the Proline bodies for the Losi or Associated? Thanks.
Jadair43 is offline
Old 02-18-2013, 08:53 AM
  #521
Slash and Burn's Avatar
Trader Rating: 24 (100%+)
I tried a friend's ProLine BullDog for the T4 and I couldn't get it to fit. I haven't physically tried the one for the 22T, but it doens't look promising. I'm hopeing PL will come out with the BullDog for the DEST
Slash and Burn is offline
Old 02-19-2013, 01:52 PM
  #522
Trader Rating: 32 (100%+)
just picked up a used desc210...what would your recommendations be for gearing a 17.5 with a 87 spur ?
thefnshow is offline
Old 02-20-2013, 07:42 PM
  #523
aquamann's Avatar
Trader Rating: 23 (100%+)
i run 75spur 26pinion with my 13.5
aquamann is offline
Old 02-25-2013, 08:26 PM
  #524
8ight-e's Avatar
Trader Rating: 58 (100%+)
Any recommends on a good clay setup.. nice size track, med-high bite. Already have tires. But you guys running a front weight or no? Shorty or long lipo? Just snagged a new kit, only upgrading the FR and RR hangers to alum the rest plan on running stock. Maybe throw a shortened desc210 bumper on the front for a skid & strength.
Thx!
8ight-e is offline
Old 02-25-2013, 09:10 PM
  #525
sparkwraps's Avatar
Trader Rating: 34 (100%+)
Originally Posted by 8ight-e
...Maybe throw a shortened desc210 bumper on the front for a skid & strength.
Thx!
Remove the maybe from there - Do it. The bumper set is like $5 and it will save your chassis. Don't wait to put it on.
sparkwraps is offline
