Team Durango DEST210R thread
#361
#363
I started with the randy pike setup and adjusted front there truck works great!
http://www.petitrc.com/setup/durango...goDEST210.html
#364
Sorry to post on all the Durango threads.. but I thought Durango lovers should be aware of this...
Someone told me.. we'll be giving away something from.... TEAM DURANGO this week on RCSoup.com!
http://www.rcsoup.com/2012/08/rc-sou...ar-every-week/
#365
I have had my truck for over a month now. I have raced it every other weekend, and I must say no one else around our area can come close. I ran it in a RM4 configuration with the stock SP 13.5 motor. I am ery pleased with this truck and have not had any issues with it. During the off season I will be putting some upgrades on the truck but overall this is a great truck.
#366
#367
I totally agree. I've run mine in RM3 in stock 17.5 class and it had too much rear traction, not usually a bad thing for a 2wd, put a mod motor in it and it came to life, great handling! I'm now going to try running it in MM3 in stock 17.5 class and see how that works, it should be great!
#368
If the car is too locked in on 17.5(mine was too) begin moving the battery forward in the chassis. Also take the rear toe down to 3.0.
#369
Best set up I found
#372
R/C Tech Elite Member
I finally was able to put some laps on mine tonight, it worked great on med/hi-bite clay..I used Randy Pike's (thanks for doing the dirty work)set up, and basically just changed tires..The truck has a really nice balance with a shorty lipo IMO, feels light, and really balanced, super easy to drive..It has a lot of rear bite in RM3, I cant remember the last time I was looking for steering in a ST..
#373
Blue Groove set up??
gonna build mine tonight! any set up suggestions for a med/high bite blue groove medium sized track? thx
#374
Current set up
Currently I am running the m3 after switching from the r3 and I have ran on carpet and clay high traction tested a variety Of wheels too foam on the carpet and bow-tie on clay I have also found out that when running m3 you need a rear Balance weight RDR racing is the best and I also have a brass weight battery stopper but I am running a shorty pack in the middle of the battery space and then use the foam spacers so the batt doesn't shift around i have run booth on high buddy Clay and carpet the best is the mid motor mount with 4 gears I had great results and good track times car handles great on both services with that set up
#375
i'll give a shot. oh, what shock oils / pistons?
