Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
Short Course Dirt Oval late model set ups >
Old 02-20-2012, 03:50 PM
Default Short Course Dirt Oval late model set ups
Im running a Sc10 Late model on clay ovals and looking for set up ideas. Has anybody tried the different caster hubs on the rear?
Mike55 is offline
Old 02-21-2012, 04:09 AM
Trader Rating: 101 (100%+)
Default Setup
One thing you can do is take the inner hingpin out and redrill a hole where the screw that holds the pin in. Then move the pin to the new location and use a 440 screw in the original hole to hold it in. Do this on the rr only. It will give you around 0 toe on the rr and will make it turn way better. You can also get higher rate springs from rc4less as the offroad springs are soft for oval.
latemodel13 is offline
Old 02-21-2012, 05:46 AM
Mason's Avatar
caster is generally on the front end of the car unless you might possibly have 4 wheel steering.
You may be referring to toe which the previous poster told you a simple way to reduce that. Generally you will be running stiffer springs than the average off-road kit springs. It really depends on your track.
Mason is offline
Old 02-21-2012, 01:53 PM
sorry your right I was talking toe, I seen some different hubs Like 1/2 or 1 I was wondering if those would be better than the regular sc set up.
Mike55 is offline
Old 02-21-2012, 03:33 PM
Default short course dirt oval late model setups
Is anyone running a xxx sct ? I am new to oval racing and im looking for some basic setup help to get me started. I will be running a late model class
stevo371 is offline
Old 03-22-2012, 01:23 PM
Sellers11535's Avatar
i do what all do ya want to know
Sellers11535 is offline
