Integy Indi Dyno ???
I'd like to know more about this dyno.
Specifically,
What does this Dyno return with an individual run (RPM, watts, etc?) and what can you gather from these metrics? Can you calculate torque?
What are it's limitations? IOW what CAN'T it do?
Finally is it worth owning?
thanx
</chaz>
Specifically,
thanx
</chaz>
Re: Integy Indi Dyno ???
Specifically,
thanx
</chaz>
Specifically,
thanx
</chaz>
Specifically,
thanx
</chaz>
Specifically,
thanx
</chaz>
Specifically,
thanx
</chaz>
Specifically,
thanx
</chaz>
Personally I feel better using a motor tester that tests the motor lying on its side, coz thats how the motor runs in our cars. When you turn the motor vertically or just simply change the angle of the motor when holding it in your hands, you can see rpm and current draw changes.
Re: Re: Integy Indi Dyno ???
Originally posted by rocketron
I would reccomend the PEAK / Orion Motor Tester. The Red PEAK unit has extra functions over the black Orion. Ability to store results is really nice to use.
But which ones are avaiblable, if I dont want to spend a fortune on a real dyno with flywheel and all? The MuchMore DO have the option of a motor holder, but it's not mounted on the motor tester, so you still easily can have the motor angle to the tester wrong... or at least not the same each time...
Whats the most affordable dyno on the market?
Originally posted by Cole Trickle
Good point.
Good point.
Currently I do the tests with my hand holding the motor and its pretty consistent. Not to mention the rubber ring round the side of the Motor Master/MPM actually acts as a guide for the motor can positioning as u can push the motor snugly into the rubber ring before commencing your tests.
Thanks. Sounds reasonably.
I've been in this hobby for some years now, but motor testing is new to me, so it would be nice, if someone can enligthning me a little...
I've read the MM Motor Master manual, so I know what it can do. But how do you use the data?
I mean, it's tempting to think the motor with highst RPM's is the fastest. But torque plays a big role on tight tracks, so how do you know which motor to choose?
What's better when checking a motor, higher or lower amp draw?
When I'm satisfied, I do the rest of my testing on the track.
Originally posted by Joe B
No-load amp draw readings don't really show anything important......unless ofcourse it's pulling 50 amps because it has a body clip jammed in it
There'll definately be a difference between a motor's performance on and off the track but at least we can make sure the motor is performing at its best in a no-load situation before mounting it on the car.
Moderator
I have bought an Integy Dyno to make sure my motors perform equally each time I put my car on the starting grid.
It's my first dyno, so I'm just starting out with it, but my plan is to build my motor up, and run it in on the dyno till the measuring numbers flatten out. I guess that the brushes should be broken in the moment the numbers don't change anymore. I want to record with what numbers what kind of performance the motor delivers, so I can define a range where the motor works sufficiently.
I have lost too much races by having a bad prepared motor, with problems like too small brushes, too little spring tension, bad alignment on the brush hoods and debris stalling the brush in the endbell and so on.
I want to use the dyno to give me the confidence that when I put the car on the grid, I know the motor will be performing as expected!
I don't think I have the know-how or the recources to tweak a motor to its limits, but I just want to make sure that the motor doesn't spoil my fun.
Any tips will be appreciated!
There's nothing wrong with the integy dyno one of the fastest guys at out track uses one to tune his motors with,like was said earlier it's a lot better than having nothing,once you get a base reading just go from there.Take good notes and you'll be set.I keep notes on motors,batteries and set ups.You've got to keep good notes if you want to be succesful,that notebook is one of the most important pieces of equipment you'll own.Try here for some motor tuning know how, http://www.motortuningsecrets.com/
