STS .28 pull-start engine
#271
Here was my truck with the STS
#272
I managed to remove the piston from the conrod. I inspected the rest of the parts closer and realized they (LHS) scarred up the head button pretty good. The part of the button that sits inside the motor is okay but the shim is damaged. And well, the gouges in the outter rim looks like it will not effect anything. What the heck is up with that? i was able to remove the head/button without putting gouges in it. I don't understand how this shop is in business and I am going to file a complaint with the BBB.
Thanks for listening.
#273
Easy, they screw engines then sell people new ones. Sounds like a great way to sell engines to me..
Nice truck does your camera have close up mode? I think we would all like to see what those butchers did to your dear STS engine..
#274
The camera I used to take the pic of the truck can do close-ups. I only have my cel phone now and will try using that.
The piston head and the button.
WITH FLASH
WITH FLASH
#275
I dont think I want to see any good quality images.. thats.... wow..
Man you must be right upset with those twits!
#276
Yeah I am pissed. But with the cost of the new piston and sleeve it will kinda be like getting a Sirio .30 and an STS .28 for $285. Although, the cost of the rotostart, battery, charger, and work I did. Anyway that is how I am trying to rationalize it.
#277
cooling head
Originally Posted by denisz
hi, does anybody know if any aftermarket cooling heads would fit this engine?
#278
roto start..
Just a message to let people know that the one way bearing isn't strong enough for a roto start.. it slips after the first time usage, I got the roto start from the guy on here that said he had them in the UK...does STS have better one way's?
#279
Sounds like the one-way could be dirty? Ive had my 2 speed one-way slip when she was not so clean.
#280
Do you mean the right side tornado part?
Please clean it(remove oil) and try again. Should be too much lube.
#281
ROto Start
Well I guess I have to tear it all apart, the roto start, (small Gear) just destroyed it self... So Back to pull start if I can find one, since my original pull start broke also... I cleaned the one way, and with it being internal, how do you keep oil off it???
#282
best not to use a fuel with more than 12% oil and store your vehicle with the nose down so oil wont sit in the bearing.
I have pullstarts for the .28 motor www.racernine.com
they arent listed yet but we do have them in stock and they should be on the site by the end of the week. if you want to order one sooner email me for price.
#283
Fuel
I am running sidewinder fuel 20% nitro and 12 % oil... and the engine loves it, when I first broke in this engine I was very impressed, now it is over heating and then the pull start went, then I got the rotostart from geggs?? on ebay, and I guess since it wasn't very good made, the small gear broke in half, after I cleaned the one way... too much poop for a cheap roto start I guess... Maybe I will just get a Sirio .30 Engine for it?? parts for this sts 28 is just hard to get a a LHS...
#284
did you check our web site my computer guy got the parts we have, listed already. the roto start kits will be here by friday
#285
When I find that it is hard to produce a perfect pull-start backplate or roto backplate,then I change the price of those parts to the cheapest compare to other manufactories. Also the piston/sleeve set. I have tried to make it better. Hope you understand. As my tests,those parts never have problem. I know that is because I know our engine and it always started at the first pull.
