Serpent Cobra GT
#601
Quick question.. Are any of you guys seeing excessive front tire wear from the box set up? I've been running Sweep 45's the last 3 weeks and have been going though a set per race day? I reached out to Sweep & on another thread here asking what I should expect and seem to be the odd one out in the longevity department. I was told going with the 10 degree camber blocks and 0 degree knuckles would help my wear problems.. Before I rush out and buy the 0 degree knuckles (already have the 10 degree blocks) I thought I would ask here?
What it turned out to be was a combination of : 1. a really exiting class of car that is far more forgiving than anything else I'd driven before and 2. A maniac driving the said car.
It took quite a bit of coaching to get me to smooth out my lines and figure out how to roll corners better by anticipating the corner more and using less brakes.
Once I'd spent time learning out these techniques, my tyre wear problem went away.
Jacko
#605
Has anyone had issues with the bolt from the steeringrack removing during a race. Last weekend at the Texas Biggie we had three cobra's run into that issue and I'm not sure what the cause is. My left ackerman screw (Part#600182) completely backed out during the race. I have raced this cobra over a year and never had this problem or seen the screw loosen. To have three separate cobras experience the same thing in a race is odd. Is the answer to solve it to buy the aluminum coated servosaver (Part#600296) so you can lock tight it in?? Has anyone else run into this issue?
#606
#607
Has the kit contents changed at all since release? I'm getting ready to build myself up a second Cobra GT and am curious about the Spider gears in the diff. Does the new kit come with the V2 gears or the original ones? I need to match these cars up upgrade wise and after using the V2 spider gears I'm in love.
#608
#609
#611
Jacko I'll see what stands out to me and let you know. My kit right now is from about a month after release so I am just as curious to see what's all in the new kit.
#613
Had a chance to run my Cobra GT with the LRP arm stiffeners and they really made an improvement on the overall steering response of the car. Turn in and exit steering were much improved and I was able to take all 3 qualifiers and the main at a local club race.
#615
