Rubber tires for dummies
#302
#304
I'm no expert, but on asphalt I've run mostly RP30 the past year and tried SXT, Ragu, WD40, Rubber Death Grip, TQ orange and GFXII and the GFXII seems the best between all of these (edit: for most temperature ranges from summer nights to warm days but not blazing hot). However a lot of A-main drivers I've seen use SXT 2.0, even some without tire warmers.
For the money WD40 is cheap and works decent. At club races I clean with WD40 unless it's a critical heat. I'll even practice with it sometimes. Maybe run WD40 for now and save $$$ for some tire warmers down the road?
If you look back in this thread and the other one cross-referenced a few posts back, you'll find a list of other recommendations, many of which don't require tire warmers. I am beginning to think that tire warmers work best with oil-type compounds that work slowly, as opposed to more solvent-based compounds which quickly "attack" the tire.
#305
thanks for the reply mike. for one i need a solvant based compound that works fast. another thing is that which of these can be shipped by air? ill do some research and find out. when u use the wd40 in practice, do u clean the tire and dry it or clean with wd40 and put on a little more as a compond? i don't see myself using tire warmers anytime soon due to time between races.
#306
can i get rubber tires for my pan car ?>
#308
Adrian - You are talking about SXT 1.0 right? The 2.0 they claim is for Foam tires. Or is there a "1.5" out there I don't know about?
#309
#310
Thanks guys for the comments, appreciate the answers from voices of experience. I see Adrian now agrees on the SXT for super hot weather, that's an upgrade from his earlier chart/listings in the thread. Some of the info is a bit dated now (only a year or two) but based on his response sounds like he considers most of it still fully relevant today.
Since I haven't tried Tweak yet (LHS having trouble getting it) I haven't tried that combo with FXII, but I think I might.
I checked some web sites and Paragon and WD40 normally can't be air-shipped. But I didn't see this limitation on tire tweak 2000 at www.towerhobbies.com. You'll just have to look around some.
You might be able to find something like these in a good hardware store, industrial supply or the like, maybe a chemicals house.
What does everyone think of the new Ragu stuff from EA? I think the conditioner is awesome, but the marinade is a lot like SXT (maybe with a touch of the conditioner in it) and needs heat to work, (although I think it works at cooler temps than SXT). What have you found ?
#312
WD 40 is a petroleum product, light fractions plus an oily constituent and I think maybe some surfactants (soapy like) and the MSDS and components are available if you search yahoo, etc. I was thinking if you look in the hardware store try to find something that functions like and has similar constituents as WD-40 (displaces water, light lubricant, etc) and try it. The more solvent-based stuff, I'm not sure which solvent it is. Just thinking you can check out what is available and try some things. If you don't have access to the name brands that's all I can think of (I'm assuming you're overseas and can't get these brands shipped to you). Another option is get them shipped but not via air. A third option is get tire warmers to help whatever you do have, and there are non-flammable compounds that are easier to air ship that work better with tire warmers.
You also asked about WD 40 treatment on tires. I use it primarily to clean the tires, but it doesn't rub totally off by itself well, so there is a little residue. To treat the tires I leave a layer on for a period of time. Only tried it a few times. Worked better than nothing. A lot of these treatments depend on track temperatures, tire compound, time for the treatment on the tires, and the type of treatment used. Basically if it's hot you don't want to break down the tire too much but if it's cool you can more afford to be aggressive with treatment. I know this is a little vague because I'm experimenting and just learning in general what to do. I can't offer exact recipes yet. Although if you had access to the treatments previously mentioned, there are other "recipes" in this thread and the other one referenced earlier, and also ones like Adrian mentioned just above. It's kind of like car set-up, there is some theory involved then as you put it into practice you make it work for you, your car, the particular track and conditions, etc. etc. thus the focus on theory not just pat recipes.
If you live in a 1-climate place then maybe someone can give you a much more specific recipe for your conditions if you describe them ?
#313
does anyone know a good traction addative recipe using household products
#314
thanks mike for all the info. i totally understand what u are saying and the info has helped alot. Wd40 is the easiest for me to get thats why im asking about it alot. i live in the caribbean and the track temp is around 36-40C on average. it surface is very aggresive and it will chew tires if the car is not set up right. i will try the wd40 to try and refresh the tire but i will get a traction compound. ill see if i can get tire tweak.
#315
excactly!
Let us "dummies" know how it turns out.
