TEN-SCBE RTR AVC 1-10 4WD SCB
#107
Ok will I dont have extra RC chassis and stuff laying around...seeing how both losi ten scbe N tha thunder tiger bushmaster are tha same price I'd rather have tha 1/8 scale motor,esc and 17mm tires already included...
#109
Was just sayin in general wasnt tryin to be a a$$ over it...I like tha looks and everythin I've read both are very good RC's ...I just seen tha bushmaster first and been stuck on getting it along with my long list of other RC's I want...Arrma Outcast, Arrma Kraton, Team Associated Pro Rally ...
#111
Can anyone comment on whether shorty packs will fit securely in the SCBE? I could use foam to take up the extra space, but it's not clear to me if the battery would be restrained on the inboard side.
#113
Anyone have any suggestions on how to get better ground clearance? I noticed the stock dogbones restrict a lot of travel. Any alternatives?
#115
Is there a consensus on diff and shock oil weights that make a good initial setup? I'd be using the buggy for general bashing.
#117
lastly, you can see the dust covers I found online for around $3. They are a close fit not perfect. They protect more than if they weren't there, but not perfect. I need some sort of clamp to put on them. Any suggestions?
#118
Take a look at the photos attached. The wheel end is a CVD, but the end at the transmission is Dogbone. I want something with a slip spline but it doesn't look like there is much room. Something like this.
#120
You're right, there is no room for splined telescoping axles on this buggy. The stock axles are plenty durable enough.
There is something wrong with your suspension. My axles don't fall out of the drive cups or bind against the drive cups at any point through the suspension's movement.
If you want boots for the dogbone ends of the axles, try the boots for the Vaterra Glamis. Those might fit better.
