Yokomo GT-4 Thread
#1036
REVELATION GT4 SETUP
(Front suspension)
shock tower : outside hole
shock arm hole: outside hole
shock length: long shock ends with 1 thread showing on shaft.
spring : green
shock oil : yokomo 650
piston : rayspeed 1mm x1
caster shims: 1thick 2.6mm and 1 thin 1.3mm behind the up arm
roll bar angle: 45
width:199mm, camber:1.5, toe: 1out total, ride ht: 4mm
droop :2mm of chassis travel from ride height before tire lift.
(Rear suspension)
shock length : standard shock ends w/1 thread showing.
spring : grey
shock oil : yokomo 700
piston : rayspeed 1mm x2holes
width : 200 mm, camber: 2.5,toe: 2.5, ride ht: 4mm
droop : 2-3 mm of chassis traver from ride height before tire lift.
sway bar standard.
Tire size 58mm
tire cmpnd 40shore
gearing 1st 15/49 2nd 19/45 with yokomo centax.
spring : green
roll bar angle: 45
(Rear suspension)
spring : grey
sway bar standard.
Tire size 58mm
tire cmpnd 40shore
#1037
Trader Rating: 45 (98%+)
Re: REVELATION GT4 SETUP
Originally posted by jwf_frani
(Front suspension)
spring : green
roll bar angle: 45
(Rear suspension)
spring : grey
sway bar standard.
Tire size 58mm
tire cmpnd 40shore
(Front suspension)
spring : green
roll bar angle: 45
(Rear suspension)
spring : grey
sway bar standard.
Tire size 58mm
tire cmpnd 40shore
Thanks a lot jwf_frani
#1041
it just happened that way because the car had a slight push
where you know it was coming from the rear being so hooked
up so i ended up using the grey in the rear wich felt better thats all. theres different ways to get the same feel or effect on the
car and thats the easiest way to do it.
#1044
R/C Tech Elite Member
Man, somethin came up and I gotta get some cash, I'm gonna try to find a way around it but I may have to sell some RC equipment, and since the GT4 was bought as a fun car more than a race car, it will propably be the first thing to go... I'll know by tomorrow if Im gonna have to sell anything or not, but if I do, you guys are the first to know about the GT4.
#1045
Hey, a fun car? not a race car?
#1049
I got a GT-4 but am havin some problems with the shiftin. IT WON'T SHIFT!!!! help?
