safe charging orion 2700mah AA batts
I picked up these 2700mah orion rechargeable AA batts and would like to charge them with my sky charger..
but was wondering if i can charge them at 1c (2.7 amp) using this battery housing safely
if not, whats the safest/max amps can i set my charger to charge them? are the wires to thin? would changing the wires to a 13awg deans help?
Thanks for the reply crusey,
but lets say i change the wires to a much thicker once, can i then charge them at 2.7amps? or is there other issues not related to wire size I am missing?
Gotcha...Thanks for all the info and help.
You charge them at 2.7amps, they'll get very hot, much hotter than they'e supposed to. You will find the cycle life is very short charging them at this high of a rate.
I consider 1amp a max charge rate for any size AA. I charge my AAs at 0.5 amps (slow charge) as much as I can.
Thanks everyone for the advice and feedbacks.
Much appreciated, to say the least.
ill keep in mind to charge my tx batts the night before and use a .5a charge throughout.
