Project: Team Associated TC9
So you making a TC6 into a Team Magic E4/TA06/JRX-S/JRX Pro/TA05
Team Magic E4: Almost Center Battery Rear Motor side elctronics
TA06: Center Battery, Rear Motor, Gear Box in the rear, Electronics Each side
JRX-S Sedan: Mid motor, Center Battery, Center Servo, Only ESC and Receiver are on side
JRX Pro Sedan: Rear Motor, Center Battery, Center Servo, " as above
EX05: has the weight pretty much centralized the most if u use Small eletronics
Wow! Nice project! I am very excited about the outcome!
I am working for some months on my own "TC9"- Project myself. I just call it KR1 because it just takes the plastic parts and shocks from the TC6.
Here are some pictures:
I am still waiting for the custom design aluminum parts. Outdrives are already made and on their way.
Here is some CAD-pic of the full car:
The car is full within EFRA-Rules as there are shorty LiPos on the EFRA battery list. So I am gonna run it on 10.5t and 17.5t LRP-HPI-Challenge events if it performes well (which is the biggest question...).
This is something I have talked about with some of my friends, and maybe it's a dumb idea, but what about an FK04 or 414MII with proper modern suspension on it? I have a hard time believing that the layshaft being high is a huge disadvantage. With lipos, you could use a shorty battery and still remain legal by claiming it is a "saddle pack" or "transverse mounted stick" car. The chassis could even be pretty narrow...
Obviously it may require moving the motor a bit, but you get the idea..
#20
#21
i don't follow how there will be enough linear throw at the shocks, but my eyes are likely missing something.
i think ridding touring cars of these tall, heavy, and outwardly mounted shocks we've been using will be the next big step that gets widely implemented across brands. maybe going to torsion springs (ala - awesometix), but perhaps keeping a thin damper tube like the 12th scales use. brings the weight down, lowers the cg, and will reduce the yaw moment ...
then again, i'm thought to do a lot of drugs.
#22
gorgeous.
#23
#24
#25
I know the motor mfgs will hate this idea, but shouldn't we be re-evaluating the 540 can size? a shorter motor with a smaller rotor and less winds could land about the same power output for everything but all out mod, you could probably shave 30% off length and weight which would bring current layouts very close to balanced...
#26
I think that would be a wonderful idea for stock. Not the same motorsize for all powerclasses! I played around with with a 380 Outrunner that brought out an equal power to a 10,5t motor. The difference in weight was 100gr.!
#28
gorgeous.
#29
Ahhhh, the old Lewis Love Machine......
