steering and handling problems (Losi 8T 2.0)
i'll be sure to check that as well...
it seems i have a fairly decent list of things to check, just need to get some time off to head to the track and start making some adjustments
i did finally figure out how to do the EPA
i'm going to start by adjusting the end points on the steering servo and see what results are yeilded, then adjust front and rear brakes for a proper ratio, then try different diff fluids and see what suits my needs best and go from there
i really appreciate all the help you guys have given me and as soon as i'm able to do so i'll be sure to let you guys know what changes i did make and how they have affected the handling of the truck
thanks again!
thanks again!
Honest print out drakes setup sheet start from there don't get lost KEY is to have a good starting setup you can tweak to your liking. Start ready the HUDY setup guide it will give you some good pointers on setup.
http://csor.co.uk/wpress/?dl_id=4
Well I have the steering problem solved, bought new servos, spektrum s8000 for the steering and s8010 for the throttle and the pretty much solved every problem I was having
My brakes in the front were way too strong so I backed it out and now it runs around the track like its on rails lol
Thanks again for everyone's help
