Lab C-02
#286
Trader Rating: 26 (100%+)
Go to the c01 thread page 116 DJ has a nice setup on there that works well for me.
#287
I was at the Byrons race over this weekend and was able to try out the new "Big-Bore shock kit" as did DJ too.
I will leave DJ to give his own opinoins and race report all I will say it was great to attend a race again, to drive a very high quality car and to have met DJ was a pleasure.
The car was more then my meager talents can handle at the moment and I was just a little rusty to say the least in all aspects.
A great weekend though. Very enjoyable and a great car.
BM
#288
Quick question, my buddy pointed out to me on tortorici(spelled wrong, i kno) car on redrc, he's running a front sway that appears to b like or right off of the 2013 nt1!! Can someone confirm if this its a direct fit?
#289
Dankel also used it at Hockenheim and most likely also at Stohr Ring too.
But why not use the one Capricorn makes ;-)... Part number are Cap-17057 Front Spool and it's 51USD bought from us for customers outside Europe. And 54USD for customers inside Europe.
All the best,
Niko
#290
Hi my friend,
All the best,
Niko
All the best,
Niko
#291
Sorry for the late reply, but been really busy with work. I went to the Byron's race and did not have the best event. I struggled a lot with keeping up with both classes and got a little lost in myself.
I did have a chance to test the new shocks some more. I used the 1.7 springs all around which felt better than the original soft ones. The car has a lot more roll in general with these shocks. I am trying to figure them out since I do not like a car with too much roll. They worked good for me once I went to the heavier 1.7 spring, but think I should have used the 1.8 in the front (even heavier). The track got to a point where it had high bite and these shocks helped with that a lot. With my normal shock set up I was traction rolling and with the new ones I did not. I think with the new springs the set up needs to change a little. I am going to Ecuador this weekend to race and will try them again. I typically run my front pins in the upper position, this will get lowered to help with the reaction of the car. I will also run the arms further back to help with on power steering. Might have to try also running the car shorter than normal in the rear to see how this helps with the reaction.
I will let you guys know, but for now I see the new shocks as better in high bite and maybe similar in low bite. Since they are new, it is about finding the balance of oil versus spring and angle of shock.
DJ Apolaro
DJ Apolaro
#292
#293
Does anyone know if the new C-02 kits will come standard with the Big Bore shocks?
#294
Capricorn Lab C02 Black Edition kit
Capricorn introduce the Lab C02 Black Edition 1/10th 200mm nitro on-road kit.
Limited to only 100 pieces worldwide the kit includes name-giving black anodised aluminium parts and the 2013 edition main chassis plate along a newly designed front upper bulkhead for improved steering response and higher corner speeds. Other items that found their way into the kit are big bore shock absorbers with new front and rear carbon fibre shock towers, nickel-plates ergal ball ends, the new F1 front sway bar, hard-coated thrust bearing holders, titanium/ergal front cup joints, heavy-weight 30mm clutch flywheel and aluminium clutch bell, 2-piece heavy-weight engine mount and the FSS radio plate. The limited edition kit is rounded out by a fuel tank brass weight, a carbon fibre battery plate and white plastic parts for the shocks and linkages.
Source: RedRC [redrc.net]
#295
#296
Let me know if you wanna pre-order and I´ll give you a good deal ...
Remember only limited edition 100pcs´s are available...
Br,
Niko
#297
Red Version looked different than other competitor cars. Now is almost identical at first glance. I don't like at all the color selection.
#299
#300
