What tires should i use?
I run on a track with slippery ground.What tires should i use?I prefer AKA and proline.Now i use proline crime fighter but the car sliding around corners.Maby AKA I-BEAM soft is a good choise?
The track in the video:
http://www.youtube.com/user/sakis9282#p/u/0/Sxc1svW75Z4
Looks like muddy, wet, tacky farm land.
I wouldn't get soft compund. You need to try harder for that surface, maybe a medium compound. Look for less side bite, more uniform knobs than the I-Beams. If you want to stay AKA, try the Crossbraces.
The other element is driver. Everyone drives different which changes their preference to fit their style, so there's probably no one good tire in these scenarios.
i run on a similar track surface. depending on how wet or dry it istheese are my top choices. and i preferthe hardest compound i can get. you want the tread/pins to dig in not bend or fold over.
schumacher spirals
aka city blocks
proline badlands
hope this helps and good luck
schumacher spirals
aka city blocks
proline badlands
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
bowtie
crime fighter
i-beams
calibers
m2/soft or m3/super soft compounds... medium to larger pin tires would be my choice.. jeremy
crime fighter
i-beams
calibers
