Team Much-More cell master v1
#766
Yes the charger is suppose to do that, when the voltage goes up, the amps should go down.
#767
Originally Posted by B&O
Well, I only put 1.0A. As the voltage picks up, charge amp starts to decrease...at the half way, the voltage is about 12.5 the charge will ended automatically. My power supply is suppling about 14V.
Someone else suggest me to get a new supply that they go up 15V and see how this will help?
this happens to me when i do my tx packs and dont have the juice cranked up
#770
Originally Posted by JL
I've just got myself a Ctx charger and after playing with it for about an hour I'm very impressed with it.
I've changed the melodies and tones to my tastes but....
How can you turn that anoying start up tone off?
I can't see it anywhere in the manual.
Thanks,
Jason
Thanks,
Jason
#771
Originally Posted by kumpol
Delta peak value setting on CTX Cell Master:
03 means 3mV (0.003V).
You can set the value from 03 to 99mV/pack
or
you can set Zero Delta Peak at 00 (0mV).
Hope this helps.
or
Hope this helps.
So if I need a pack to peak @ .02V, that means I'll be setting the charger to 20??? Is my math (thinking) correct?
thanks,
Dom
#773
Originally Posted by Sushi Boy
Yup, but the thing about the cell master is it's a super linear charge, so the actual peakl detect is a little different. I basically adjust delta peak to get the correct final charging temp.
Dom
#774
Hi Sushi boy
I think, final charging temp is affected by outside temp.
The starting temp is very important.
Low starting temp(cold battery) makes low final chrging temp.
Low final chrging temp means that loose punch.
Much More Battery Warming Tray is warmer that can heat up your battery
before charging.
Too high delta peak makes over charge that reduce battery`s number of life cycle.
Correct charging method give you more punch and long life of your battery.
Sorry for my poor english.
Son In-Kwon
from south Korea.
before charging.
Son In-Kwon
from south Korea.
#775
Thank you for your advises.
I will look into a new supply with 15V...... Not too many charger can withstand high input though....
#776
Hi guys. What settings do you use for Tamiya 2400 Nicd stick packs? Thanks...
#777
so what is a good temperature when the charging is finished?
slightly warm? 40degree C +? or ??
that's for the GP3300 or 3700..
#778
Originally Posted by TeamMuchMore
thanks arun for always helping muchmore guys on rctech~
Originally Posted by lightspeed-dom
Thanks Kumpol, please allow me to throw out an example and for you to check on my math...
thanks,
Dom
thanks,
Dom
05-06 (.005V-.006V) is a good starting point for IB cells.
Refer here for some more info and starting points for charging IB cells.
As a general rule:
Lower charging rate=more run-time, less power
Higher charging rate=more power, less run-time
NiCD's also like higher delta peak settings. I would start with an 09 or 10 setting.
Additionally, a stick pack has more resistance in its connections. This can cause a false peak, especially in combination with lower delta peak settings, so you will probably want to set a long-lockout for the first 10-15 minutes of charge.
#780
Originally Posted by babytoy101
hi!
what does the flex feature do on the battery when i enable it on mm cell master? like in ni-mh battery!
You can envision it as something like this:
charge -> charge -> charge -> quick discharge -> charge -> charge -> charge -> quick discharge
This is one form of flex charging. Most chargers thatcan flex have the option of increasing or decreasing the intensity. This is accomplished in the setup menu for each profile on the cell master...Fn (no flex), F1, F2, F3, etc
The best way to get performance out of your NiMH batts (today, at least), though, is either with a linear or CTX charge. Some who have flex charged their NiMH batts have reported a decrease in power.
A lot of us are now starting to basically flex-discharge our batteries with the Spintec Battery Manager and Trinity Dyna-Pulse dischargers (and upcoming CTX-D from MuchMore ). These units will pulse/flex-discharge your packs to condition them and keep them good.
I'm sure flex charging will make a big comeback some day...just like dead-shorting did .
