Team Much-More cell master v1 >
Old 08-15-2005, 01:13 PM
  #646
brandbrainz's Avatar
Default Problem with Cell master
My Cellmaster shows 0.310 V for a 6-cell battery pack and stops after a few seconds charging with low cell. I've tried all my packs and the error occurs with all. I've also checked the thin wires for current detection and run a few resets.
Can anyone help?
It's a bit urgent because we have the german nationals in 10 days time :-(
brandbrainz is offline
Old 08-15-2005, 05:49 PM
  #647
Bryan Thng's Avatar
a buddy of mine had the same problem as well after about 2 months of getting it... Ryan did advised re-soldering the thin black wires on the crocodile clips several posts back... but we haven't had the chance to try this fix as the charger had already been brought back to the dealer to have it sent for repair by then... its been about 4 weeks already and still no news of it though... i do hope a simple fix will work coz its a nifty charger, quite unfortunate if it is marred by such bugs... i have one myself, hope it doesn't give me any problems
Bryan Thng is offline
Old 08-20-2005, 11:39 PM
  #648
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default temp probe magnet
Ryan, Keith or James...
Do you guys have any plans to modify the existing temp probe so that it can be placed within a magnet? the team orion advantage temp probe is efficiently designed with the temp probe inside a magnet. and the magnet is curved so it sits perfectly on top of a cell. it'd be a good "hop-up" for the charger. just thought and curious. thanks!
Keith... see you at nats! when are you arriving?
- Chris
Hebiki is offline
Old 08-22-2005, 09:00 PM
  #649
TeamMuchMore's Avatar
Yeah it's pretty cool hop up but we been using our temp sensor just fine.
here is the big question how are we gonna use the round magnet sensor with battery heatsink?
- Chris
TeamMuchMore is offline
Old 08-23-2005, 07:51 AM
  #650
Nexus Racing's Avatar
I guess both types of temp sensor have their advantages and disadvantages. It is nice how the MMR one is a little more versatile. I like how Ryan Lee mounts his MuchMore temp sensor when using the heatsink:
Originally Posted by Ryan Lee
Nexus Racing is offline
Old 08-24-2005, 02:12 AM
  #651
Hebiki's Avatar
hehe.. it all depends if keith brings them
i was just gonna get the magnet container..and throw that around the MMR temp sensor until i get my heatsinks. *hint* *hint*
btw.. James, you coming down for nats also?
Hebiki is offline
Old 08-24-2005, 02:57 AM
  #652
Piyo Piyo's Avatar
Default False Peak on CellMaster
I experienced false peak at the start of charging with Linear Charge function. Delta peak set at 0.05, charge rate 5A, 3300 GP matched batteries. While with Turbo 35 or ProTrak, I don't encounter this problem.
Anybody can help? Thanks in advance.
Piyo Piyo is offline
Old 08-24-2005, 07:38 AM
  #653
A 05 setting on the Cell Master is actually .005, not .05.
The MMR super linear current does not require high delta peak settings. The battery can false peak in linear mode if the battery has been trayed or dead-shorted.
In CTX mode, the battery will not false peak, because it is locked against delta peak in the first two phases.
If you use regular linear mode, you should set the long lockout. The setting for the long lockout is in the main setup menu (hold down "<" for three seconds). After you start charging, then hold down ">" to activate the lockout. You will see the key pop up on the screen. During lockout, the charger will still peak if the battery temp reaches your set temp cutoff.
Or, you can set up a CTX profile with 5A in all three phases...5A to 2500mah, 5A to 2600mah, and 5A to 4500mah. This will still be a linear charge, but makes it so you do not have to set a long lockout .
Old 08-26-2005, 10:14 PM
  #654
noline's Avatar
Ive just recenlty purchaced a Team Much More Cell Master Charger the problem Im having is that when im in the step 2 mode the charger will charge a little bit and then it willstop charging and it will do this over and over till I get a Error message check clip Do I have this setup wrong or is there a defect with the charger my setup is
Step 1
2650 ma 7.0a
Flex off
Step 2
2680ma 0.2a
Flex off
4200ma 6a
Flex off
delta peak 09
It does it every time it goes to step 2
your help would be greatly appreciated
Im using 3300 Dead shorted batteries
noline is offline
Old 08-26-2005, 11:02 PM
  #655
TDO
TDO's Avatar
Just another questions (perhaps already answered somewhere in this thread..). I have set peakdetection at 8mv. Is the peakdetection per cell or per 6-cell pack?
TDO is offline
Old 08-28-2005, 09:31 AM
  #656
Step 1
2650 ma 7.0a
Flex off
Step 2
2680ma 0.2a
Flex off
4200ma 6a
Flex off
delta peak 09
Check to make sure that the flex charge is actually off. It should say "Fn" in all the CTX setup menus. When I first tried the CM, I thought that "F" meant "fan", and my charger did the exact same thing.
I don't think that it is possible for the CM to flex charge at only .2A, so it cuts the charge off.
Old 08-28-2005, 09:39 AM
  #657
8mV (a setting of 08) is for the entire pack, no matter how many cells .
Old 08-30-2005, 01:05 PM
  #658
Joep's Avatar
Maybe allready asked & answered but:
1) is the cutoff voltage when discharging for the pack or per cell?
2) is it possible to discharge and then charge in a cycle ones instead of charge and discharge?
Joep is offline
Old 08-31-2005, 06:54 AM
  #659
TDO
TDO's Avatar
Thankx Nexus
TDO is offline
Old 09-01-2005, 10:51 PM
  #660
carkillaii's Avatar
PLEASE HELP ME. I plugged in my pmwe and a bright spark came out of the box. I opened it up and the 250 v 5a fuse was blown, but I changed the fuse and still got nothing. What the HELL do I do?
carkillaii is offline
