Team Much-More cell master v1
#1561
Originally Posted by Centerfire
A. Rhodes : Thanks! what do you mean 14 peak detect outside w/ heat sink? how will i set that?
You can use the temp feature in the CTXC and directly wire the heatsink fans in so it starts and stops at certain temps, or just run it off a power supply.
#1563
A. Rhodes : Ok, i got it! thanks! what is the difference using 21 delta peak settings compared to 14 of Big B? does it give more punch and power?
#1565
what's the best setting for tamiya 1600SP? i will use it on m03 using black can. do you think the step charging is ok in 1600SP?
#1567
#1568
Originally Posted by Big B
I have not used the step charge cause I have no Nicd batts, but it looks to be the best way. I would try and contact MMR on that one.
SANYO NiCd 2000Mah use 018-022
#1569
Hi Guys, just got the charger and was wondering if someone could help me. looking to charger Tamiya 1600 NiCd and Sanyo 2400 NiCd. What seetings should i use for these batts. I will be running the 1600 with mabuchi silver cans and 2400 with sports tuned. Thanks guys.
#1573
Does anyone know whats the speed of the internal fans in the CM? Need to find a replacement for mine...
#1575
we use 7A to chg Sanyo 2400 for Tamiya cup
