Xray T3 2012
#1141
Changing the link length without changing the link angle relative to the arms has no effect on static RC, it only changes what the RC does as the car rolls. Short links cause the RC to rise as the car rolls, so will roll initially and then stop giving a more reactive feeling, long links cause the RC to stay low as the car rolls, so will roll more mid corner (at that end).
So back to the original question, I would lengthen the front link to make the front end roll more mid corner, and I would not lengthen the rear links unless you want a more stuck rear end.
A 3k rear diff is pretty heavy so I would look for on power steering elsewhere, less front droop is a good place to start and a harder rear sway bar also works well on the xray, less rear toe is good if you need steering in high speed sweepers.
#1142
It was a trick question I just wanted to understand why Artwork believed it did.
#1143
composite shims
Hey,
Thanks for all the explanations on turnbuckle positioning, very useful!!
I was wondering, appart from to save weight and the fact that they are cheaper to produce, why are composite shims used instead of alu ones either side of the wishbones, any ideas?
#1144
Could anyone help to give me some advice?
The current layout of the track I'm playing contains lots of short straights then U-turns.
My T3 2012 is lacking mid-corner steering and also experiencing on-power push. Seems the rear is dialed too much.
I'm using basic asphalt setup except with 3000t rear diff oil and 1mm inner camber link shim both front & rear. Have tried using smaller deg of diff oil but push even hard.
#1145
when building the 2012 for high grip carpet, what would be a good starting point, build it like the kit, or is there a link to a setup that works well, thanks
#1146
The kit setup seems to be a good starting point.
Dave Locke ran his stock setup with 600cst F/425cst R with good results at Lou's (high traction carpet, where you race haha). My preference was 575cst F/500cst R.
#1149
Why are you asking questions that you clearly know the answer to...is it to be a jerk?
Just to be fair...please respond to every roll center or link length questions going forward...to save us all the embarrassment. Oh and please include all threads on RCtech...thanks!
#1150
Not meaning to sound like a jerk, I wanted to understand why you said that - now you have answered because the link angle changes slightly, unless you compensate
There's some great reading on roll centre here
http://users.telenet.be/elvo/3/3.html
#1151
hi, I do not like taping in my batteries, and was looking at the xray lipo battery graphite strap part number 306163-K, any one have one intalled on their car, how does it work, it says it will not tweek the chassis no matter how tight you screw it in, so those who have it is this a true statement, as it would be a great option for me but not sure about the claim, thanks
#1152
#1153
Use tape.
#1154
This is a good piece of information
Originally Posted by http://home.scarlet.be/~be067749/58/
In general, you could say that the angle of the upper link relative to the A-arm determines where the roll center is with the chassis in its neutral position, and that the length of the upper link determines how much the height of the RC changes as the chassis rolls. A long, parallel link will locate the RC very low, and it will stay very low as the car corners. Hence, the car (well at least that end of the car) will roll a lot. An upper link that's angled down, and very short will locate the RC very high, and it will stay high as the chassis rolls. So the chassis will roll very little. Alternatively, a short, parallel link will make the car roll a lot at first, but as it rolls, the tendency will diminish. So it will roll very fast at first, but it will stop quickly. And a long link that's angled down will reduce the car's tendency to roll initially, but as the chassis rolls it won't make much of a difference anymore.
In terms of car handling, this means that the end where the link is angled down the most (highest RC) has the most grip initially, when turning in, or exiting the corner, and that the end with the lowest RC when the chassis is rolled will have the most grip in the middle of the corner. So if you need a little more steering in the middle of the corners, lengthen the front upper link a little. (Be sure to adjust camber afterwards) If you'd like more aggressive turn-in, and more low-speed steering, either set the rear upper link at less of an angle, or increase the front link's angle a little.
