Xray T3 2012
#1637
#1638
So, both of you guys(bozzplayer and theatriks) are coming to the Canadian Onroad Nats, in less than 2 weeks, to show us all your skills, right? :P
#1639
#1640
I recently broke my car, and the factory replacement is out of stock:
http://www.amainhobbies.com/product_...int-5mm-Open-8
Will these work in stead?
http://www.amainhobbies.com/product_...ctional-Open-4
#1641
http://www.amainhobbies.com/product_...Joint-w-Hole-4
Which will require you to use these instead of screws;
http://www.amainhobbies.com/product_...w-6mm-Thread-2
With 10mm versions for the C-Hubs.
#1642
Yes, I would look into changeing to these in future;
#1643
#1647
#1648
Those do look really nice. I'll probably stick with the kit ones though.
I never thought I would say this before owning a T3, but I actually like the kit plastic shocks. They seem to last longer before requiring a rebuild than the aluminum shocks I've used in the past and the shafts don't get scratched up so easily.
#1649
In Xray forum it was said that he was NOT running the 2,0mm.
#1650
I found that once the plastic shock body's get some grit or muck in the threads on the shock body, the adjuster gets stuck easily and then the threads get ground down which just makes it all even worse. THe alloy shocks put up with muck a bit better.
Skiddins
