Programming GM esc with GM Commander
Has anybody done this? I am looking at getting a GM Commander so I can. Is it easy to do? My main question is can the older esc's be programmed? I assume they cannot.
I have a gm commander and it does program your esc. It works kinda like your old novak pit wizard. The Charger on the other hand is top notch and I would not get rid of it. I got mine used on Ebay then sent it in to Horizon Hobbies for a tune up, It looks and operates like new and I love it. I would highly recommend the Commander just for the charging features and if you have a gm esc it becomes that much better.
Hope this helps
Stephen <><
Hope this helps
Stephen <><
But will it program all GM esc's or only newer versions?
the GM Commander can program either SX9 or SX12.
Hi Shookie,
Which charge mode you are using? e.g. Peakchg, Tempchg or GMVIS charge mode?
