Tamiya 1/12 R/C RM-01 "Racing Master"
#391
When the Porsche is available, I'm not going to beat around the bush...
#392
Finally, I got to race my RM01 today for the first time.
It was dialed out of the box, just on the kit foams, I am very happy with this car!
The track was medium to high grip smooth tarmac.
I wore the fronts out after 3x 6 minute races. The rears still have another race or 2 left in them.
There is no 1/12th class at this club, so I was allowed to run in with the F1 cars ... 540 silver can motors only.
I used a giant old LRP ESC, the only brushed ESC I have, Futaba 9550 servo and an IP 1600mah 40C 2S lipo - designed for 1/18th cars.
Ready to run weight of 775 grams.
The club has a minimum weight of 1000grams for their F1 class ... so to be fair I had to add 225 grams of lead to the chassis. I think the chassis looks hilarious now, it took some time but I got it to the legal weight, check it out:
#393
1kg 12th scale
http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
#395
The option tires will last longer, you may want to give them a try.
1kg 12th scale
1kg 12th scale
Fronts showed minimal wear and had great steering on the rug as compared to the kit fronts which wore wicked fast with similar grip.
Rears were great and like the kit rears, had great grip but seemed to allow the car to rotate better and also showed minimal wear, also similar to the kit rears.
Grip felt consistent thru entire 8 minute runs.
Thanks for the heads up and all of your help today Redbulldude! Car feels better and better each run.
Sean/TQ Raceway, thanks for having all the good stuff for this new car within arms reach right when we want it.
Fun day out there today, again.
#396
[QUOTE=RedBullFiXX;10315598]The option tires will last longer, you may want to give them a try.
1kg 12th scale
Thanks, I have those tyres in my pit box, I didn't want to try them as the set up seemed good already. But will give them a try next time.
The difference in lap times between a car at 775 grams versus 1000 grams was just on 0.5sec per lap slower
1kg 12th scale
#397
[QUOTE=Tim K;10319936]
So in a 40 lap run @ 8 mins, that would be 20s, or approx 2 laps
Did the RM spark up any interest at you track for 12th scale ?
The ease of getting into the class with this car should bring in a few more racers.
1kg 12th scale
1kg 12th scale
#398
[QUOTE=RedBullFiXX;10320251]It did in Dallas. Added one 12th scale racer that would have never considered the class if it was not for the RM01. The awesome looks and low price drew him in and the performance made him want to race. I provided one of my old AMR12 bodies to race with so he can keep the Tom's body in one piece.
#399
#400
Any "must have" hopups?(aside from the non-existent carbon rear axle)
Will be running high grip carpet (till spring)
and med grip asphalt.
Gears are turning.....
#402
#403
We are running the car with the 12th 17.5 blinky class here.
It may not be the fastest car in the class, but it holds it's own, and is super easy to drive, with virtually no setup.
For Must haves ...
Grab the option tires, they are much better for durability, and help with consistency for the full 8 min run.
As soon as the other hop-ups become available.
All the carbon, aluminum pod bits, kingpins, and center shock.
The kit side damper, is lightweight, and does the job.
Side springs are the same size as AE.
For Must haves ...
#404
Newman Order Update
Email received this morning:
The comments for your order are: Hi there Grant.
Firstly, our sincerely apology as Tamiya 58251 is not available till around 24th March. However, due to our staff mistake, in stead of pre-order form, they have turned on as in stock item.
I can issue immediate refund or we can ship the products as soon as we have them in stock.
Please reply to this email and let us know.
Once again, our apologies for any inconvenience we may be causing.
Yours Sincerely
Banzai Hobby
Yours Sincerely
Banzai Hobby
#405
He has added the CRC oncore shock and alloy diff and left hubs. Everything else including tires is right out of the box. Very easy to drive and suprisingly fast.
