SpeedMerchant Rev.7 >
SpeedMerchant Rev.7
SpeedMerchant Rev.7
Old 01-25-2012, 01:51 PM
  #256
Paul Lomas's Avatar
Originally Posted by reynard55
I got to run my Rev 7 at the UK nationals last weekend. The car was absolutely brilliant
It was so easy to drive, held corner speed unbelieveably well and caused quite a stir over here.
Recently I have been a D/E final driver at the nationals, with the Rev 7 I qualified in the C on the Saturday with 10.5 blinky and in the B on Sunday in Mod.
There were a constant stream of drivers curious as to what this super handling car was.
It was pretty much box stock, just added the Tamale pod. Setup was 020 springs F/R, 10k diff lube in the sides, Asc blue and 40w in the centre. Jaco magenta front and pink rear.
Thanks to Bruce and the guys on this thread for the info and guidance, I am very much a convert
I was there at the weekend, moving out of the way, and later watching from the sidelines, and the car really is amazing. I'm now looking forward to my own!
Paul Lomas is offline
Old 01-25-2012, 02:03 PM
  #257
tim fry's Avatar
Has to be done
tim fry is offline
Old 01-26-2012, 11:50 AM
  #258
wingman2's Avatar
I wonder who's car this is (was spotted at the Plymouth national by myself!)....
Cheers!
wingman2 is offline
Old 01-26-2012, 10:30 PM
  #259
b_recliner's Avatar
Trader Rating: 22 (100%+)
Is there any way to influence camber on the new old school front end. I know it's supposed to be machined in, but I'm getting some radically different readings on the hudy station and was wondering if there was a possible remedy. Thank you fellows.
b_recliner is offline
Old 01-27-2012, 03:53 AM
  #260
It's easy enough to make your own thin shims for adjusting the camber. Two easy materials to use for shim material are either narrow strips cut from a sheet of 600 grit emory paper, or else thin slices of regular masking tape. I use the tape (with the sticky side towards to the plastic block) so that the shim then sticks to the block and doesn't fall out during ride height adjustments. Adding 1 thin strip of masking tape equates to about 1/2 degree of camber change. I also recommend that you don't need to use any fancy setup guages. When you've shimmed your arms so that the car wears the front tires flat.......that is the sweet spot (because you'll be making maximum use out of the full width of the tires)
vafactor is offline
Old 01-27-2012, 04:11 AM
  #261
My setup from last weekend's meeting
File Type: pdf
reynard55 is offline
Old 01-27-2012, 10:55 AM
  #262
tim fry's Avatar
Looks very similar to my setup. What was the benefit of the 1mm shim on the outer steering ball?
tim fry is offline
Old 01-28-2012, 12:26 PM
  #263
I did it to reduce bumpsteer, with the servo and servo saver combo I have the trackrods had too much angle in front view for my liking.
Old 01-29-2012, 10:31 AM
  #264
tim fry's Avatar
Did you try running it without the shims? I had the same idea as you but left it as a few pages there was some discussion about the angle and it was felt it wasnt a problem. I might try it and see how it affects the feel of the car.
tim fry is offline
Old 01-29-2012, 10:36 PM
  #265
flameoutgarrett's Avatar
Good luck to Bruce and all the crew at snowbirds! Remember to sleep and have fun, next year I'm planning on comming back for the excitement and sleepless week next year after a few years off
flameoutgarrett is offline
Old 01-29-2012, 11:23 PM
  #266
Suspended
I took care to make sure both of my blocks were 100% symmetrical left to right, and both are 2 degree of camber and 3 degree of caster. I typically always run this, but to get 1 degree I took the .25mm ride height shim and sliced it down the middle. This way you can put the shim inboard and it will take 1 degree of camber out.
(see the pictures for clarification.)
We do that here on our bumpy track, it seems to eliminate almost all of the bump steer. We have some extensive rhythm sections on our track.
Attached Thumbnails SpeedMerchant Rev.7-img_0843.jpg   SpeedMerchant Rev.7-img_0844.jpg
Wes Briscoe is offline
Old 02-04-2012, 09:38 PM
  #267
Suspended
Congrats to Peter, 2012 Snowbirds he is TQ in 17.5 1/12 and World GT with his Speedmerchant rides. Good luck tomorrow!
Old 02-05-2012, 08:59 AM
  #268
GO PETE! He's laying it down for the speedmerchant camp!
Old 02-05-2012, 09:12 AM
  #269
b_recliner's Avatar
Best of luck and skill!!
Old 02-05-2012, 09:37 AM
  #270
TQ and Win snowbirds 17.5 GTP class. Awesome job Pete.
JoelV is offline
