Gear cover for BK2
Gear cover for BK2
The old RPM cover will work on the Gen ll tranny. All you need to do is mount the cover using the original rear hole on the motor plate. Then center the front mounting hole of the cover between the front mounting hole for the cover on the tranny and the hole for the tranny bolt. Drill the hole with a bit slightly smaller then the bolt. Once you get the hole in the plate I used a small reamer that came with my Dremel and just slowly made it bigger till the screw fit. Then just use the screw to cut the threads in the plate. It fits really well and does not rub anything at all. Losi should just put this hole in the motor plate to begin with so you can use the RPM cover out of the box.
RPM making one now for the BK2 and MF2
73342 (Black)
73345 (Blue)
73347 (Yellow)
