Whats the best way to get stripped clutch bell hex screw out?
I'm a idiot I stripped the screw on my Losi clutch bell and jx.21 , so know I can't change shoes or bells. Whats the best way to get this stripped hex head clutch bell screw out? I should have bought better hex drivers I guess! Thanks for any help with my screw-up!
If the screw stripped obviously the screw is being held on their tight, give it some heat with a heat gun and then open it up, or you may risk of snapping the head after you notched it.
I would personally use a strip screw powder which you can find at ace hardware put some in there and see if it helps first make sure your tool tip is in good condition.
If that fails then resort to your notching.
Really?? Strip screw powder??? Never heard of it. How does it work? I cant see how sprinkling some powder on the outside of a screw will help, or is it like a pressure sensitive glue that helps the hex grip the inside of the screw head?
I've always used the dremel to slot the head and as long as you keep the groove neat and as thin and straight as possible you shouldn't have a problem. The beauty of a clutch bell screw is it sits proud of the surface so you can get a nice groove without damaging anything else. Countersunk head screws and grub screws are the worst.
personally i replace the the screw every 2-4 clutch bell bearing changes saves it getting stripped.
but as everyone else has said use a dremel.
Buy this best tool this should be in ever tool box saved my ass many many times best one was a clutch screws broke in the crank shaft with the blue stuff BAM no issues. WORKS REALLY GOOD
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
Regional Moderator
I too have used the dremel and screwdriver to remove bad screws.
About a year ago I switched screws and am using a slightly longer threaded Kyosho screw from my RT5 kit. Much better quality wrench tip hole. I also do not use any loctite on this screw. No problems on it coming loose or getting it out when I want.
