Anybody use mx chain wax?
I've tried a chain lube before, to coat my buggy, didn't like it. I don't have compressor to haul to track so I'm trying a better brand of chain wax to coat my buggy. I'm trying to keep buildup of dirt to a minimum. After spraying do you let it sit up like a mx chain or do you wipe it down?
Thanks.
Thanks.
I use motocross Chain Wax on my CVDs. It keeps them lubed and doesnt collect dust like grease. Chain lube does collect dust and i do not recomend it. Wax is the way to go for keeping your drive train smooth.
Ok thanks.
simple green magic. works great.
dont use chain wax. just to sticky
Chain Lube is always sticky and collects dust and dirt. needs to be cleaned off and reaplied oftenly.
http://www.motosport.com/dirtbike/pr...-OZ/?id=106231 I do not remcomend using this on CVD's or drive train parts.
I recomend using Chain Wax. Once dry, less the 10 min, It doesnt collect dust or dirt. It just wears off and you simply reaply more. The link below is what i use and recomend.
I ride alot of motocross and found Chain lude works awesome on chains that are abused by being drug threw mud and sand. One day i put it on my CVD's and Diff pinion and ring gears and have used it ever since. I do not remomend using it on the bottom of a chassis to keep clean or what not. just on drive parts that need lube.
Thanks for replies.
