assemble stick packs
is it possible to assemble stickpacks???? i got a modded tl01 and i dont think normal assembled packs fit do they???
or you can do what i did .....make a bottem plate[alu/carbon/fibreglass/etc.... and boly it onto the chassis then you can use sadle/ladder/stick pack batts and you also have a lower c.o.g. so itll handle batta
i dont really understand got any pics so u just put a sheet of carbon/fibreglass on the chassis do u put it on a certain side or can u center it???
im brawin it up in paint.......................... back in 5
Another way I do micro stick packs is I take two wooden dowels and tape them together and now the batteries fit nicely in the wedge the dowels create. I bought a hammer head soldering tip, and what this does it allows you to get between the batteries, heat up both ends, then push them together quickly. Or you can take a thin piece of metal, copper if you can, and solder the end to one battery then the other, and fold the metal between the batteries. Hope this helps, I might have a link for a site that has a great diagram for this onmy home computer, if so I will post the link,
its dodgey but its good
here you go
oh so u sort of made it a tray type car thanks m8
no warrys......................you should also invest in a spare chassis in case stuff happens
i actuall first made it as a bashplate so wen i rally raced it it whouldent break but then i cut it out so it takes ladder packs now
is there a way to make them without a hammerhead soldering tip???
The trinity kit is the easiest way. Other than that I wouldnt recomend just butt soldering them it would make it hard to get apart if you have to. A thin piece of copper works well as does battery braid. Al you do is lay the cells side by side like your making a ladder pack after the bar or braid is soldered on just fold the cells ends together. I made some for my starter box and just used double pieces of solder braid.
how does the trinity thing work i need to do some thing for my f201 i would hate to have to buy anything just to run besides my hobby shop dont sell them things
i cant find the trinity pack anywhere that ships internationally BTW im in australia
any 1 noe of any place that stock it
wait found some trinity stick pack building kits on tower so getting 4 stick packs done with Epic 24-Cell Bulk Power Brick VIS
so wiht the building kit do u just solder 1 end of bar to other end then fold bar between them???
