RDLogics Mongoose
#1471
Red Spring
Originally Posted by rcrevolution
hey I run the red spring with no brass weights in the shoes how much should I tighen the spring?
I have it at .5mm with about 1 or 2 threads showing, and it engages sorta early.
should I go to like 3 or 4?
#1472
Should I take out the brass weights? I have teh red spring in, the problem is i haven't had time or found a suitable place to break in my engine. So, before i have any problems with my clutch should i remove the brass weights?
#1478
i love how everywhere i go i am seeing madza 6 bodies, i have the same exact body painted in all black.....
anyways, i have a new problem, where steering servos do you guys run in your mongoose or g4?
I need a new one but a I want a good brand perferably hitec.
if I can get a decent one for around $50 or less it would be great.
what should I be looking at for speed and torque?
or does anyone have a servo thats good.
#1479
Im using for steering and for gas/brake 2 Hitec 635HB's ... 6kg of torque at 0,15 segs. Enough for nitro 200mm racing ... im using them for about 4 months without any issue ... enough torque for the light weight G4 steering system ... and CHEAP !!!
#1481
ok now I have the RD Mongoose with the k-factory steering rack, is that lightweight?
and how do you like .15sec? fast enough?
I was looking at the 625MG
Yes the last system mounted over ball bearings its very light weight, i see not a single problem with my 6kg servos doing the job ...
And about the .15 segs ... i think is enough ... at least for me and for the kind of tracks i have around here ...
cya!
#1482
does anyone know the part number of this ball cup? it seems different from the rest.... 4mm?
And is it just me, or does anyone else find the handle a little badly positioned too far back causing the car to tilt forwards when u pick it up, often having your fingers touch the burning hot engine head?
#1483
The handle feels a little too small for me, that's why I pick my car up from the head of the engine
#1484
You guys can use 3Racing alum handle for G4. Pretty nice design.
