batterie charging at 4000
im charging a gp 3300 at 3.8v and it says the batt is at 9.15 volts at 4000 mah im charging know so if you can help please tell me right away before it blows up.........................its a new batt that i got today
Re: batterie charging at 4000
it stoped charging.......its not that hot but the 4095mah that the pulsar says is warrying me a bit
thanks for the info i thought i stuffed it
When i deadshort my packs, i charge them at 6.5 amps and they get up to about 4200-4300....totally normal.
-Buddy
-Buddy
yeah .... that will happen when u get new cells an charge them 4 the first time ..
mine do 4000 almost every charge .... due to the fact that i take my cells down to zero ..
that good cos its not even my batterie it my mates[i built it for him cos he is uselus]
since its a new batt .. u might want to cycle it two or three times
so it comes to life (wake them up) ..an perform at it's best straight away ...
just a suggestion ...
im dumb
how do i do that
ok
all u do i charge the battery up at 4amp (or ur disired rate)
once done let it cool ...(if u like u may re-peak it )
then discharge it at 20amps(if possible)
do this 2 or 3 times an u should b good ...
thats wat cycling batts is ..lol
OMG !!! it's super rare battery !!! where did you got it?? ........ it's normal u know, latest gp3300 will hit over 4000mAH at low amp charging.
its the first time ive actually looked at the mah thing on my charger...............4000 isnt rare lipo cells go over 6000
On a brand new good set of cells I will easily put over 4300Mah in. Of course this will not be what you get out, which is of course the most important part. I can put in over 4000Mah into my 3 yr old cells. Expect to only get around 82% to 85% back out on discharge.
