synthesised .........
does any one know if my standard fm 75 receivers will work with a jr or other synthesised transmitter?....I know I would need to use a crystal, and I plan to get a couple more synthesised receivers, but for now Id like to use my old ones
thanks in advance Gary
btw the ones I have are futaba
First off... do you already own the Transmitter???
Novak recievers will work with just about any radio....
Futaba/Hitec are compatible...
Airtronics/Jr are compatible...
If you own Futaba and don't want to replace them then go either Futaba or Hitec.... I have a 3PK and absolutely love it... Read our little post, you learn something new each day.....
The JRXS will work with any POSITIVE shift RX. That rules out Futaba and most hitec. There are some receivers out there that work with both positive and negative shift. I have a Jrxs and I know that it works with ; jr (obvious), multiplex, KO, Airtronics, Novak. That's all I have tried.
