Help with putting a losi clutch on a Novarossi 4btt >
Old 07-01-2011, 01:28 PM
Fortega95's Avatar
Default Help with putting a losi clutch on a Novarossi 4btt
When I put the fly wheel on. Then I put on the clutch bell. The clutch bell want shit flush whith the clutch bell baring so when I tighten it it dues not move free. Plz help
Fortega95 is offline
Old 07-01-2011, 01:36 PM
merdith6's Avatar
Default I think
The losi flywheel should come with it's own collet, the wedge shaped piece that replaces the stock steel one on the engine.
First remove the stock Nova collet and put the losi one on in it's place.... the flywheel should fit perfectly on that one.....
I like to use a tiny flat screwdriver in the gap on the collet and twist slightly and slide it off....make sure the new one is all the way on before putting the flywheel on it. pull the crank out as you slide it on....
merdith6 is offline
Old 07-01-2011, 01:43 PM
Fortega95's Avatar
Ya I tried that but I sheems like the crank rod is to sort. So when I try to put the clutch bell on will not sit flush with the clutch bell bearing.
Old 07-01-2011, 01:44 PM
808gx7r's Avatar
use really tiny shims and shim the end of the crank so screw doesnt bind with bearing
808gx7r is offline
Old 07-01-2011, 01:48 PM
dsl
dsl's Avatar
It should fit fine with the Losi collet, I've run several Novas with that clutch with no problems. If not, you can get the OFNA shaft extender and shim kit or simply grind 1-2 mm of the bottom of the collet and that should give you the play you're looking for.
dsl is offline
Old 07-01-2011, 01:51 PM
RacerScott's Avatar
Are you using the losi clutch bolt washer? It has a recess that goes into the bearing a bit.
http://www.amainhobbies.com/product_...dware-8IGHT-20
RacerScott is offline
Old 07-01-2011, 01:56 PM
Tech Prophet
houston's Avatar
Trader Rating: 96 (100%+)
the losi should come with a shaft extender in the kit which is what you need to use if the bearing sticks out past the crank the nova engines have a stepped out inner race on the front bearing as to aleviate the need for shims behind the collet on certain manufacturers clutch systems , not needed on the losi but that is what it is and one other thing to be very sure of is to make sure the crank is pulld all the way out and the collet is slid all the way on
hope this helps ,
Monty
houston is offline
Old 07-01-2011, 02:09 PM
Fortega95's Avatar
Just went and got that now how shood I shim it
Old 07-01-2011, 02:36 PM
merdith6's Avatar
Default Ooops
Sorry buddy, I misread the post....
Yes the bearing sits just outside the crank. Like the above post said there is a tiny shim that fits just inside the hole created or the steel end piece will fill it in and the add regular shims to give it just enough play to spin freely after tightening it down really good....
when I worked on Losi cars I just used the tiny shims and one flat cone washer and it fits nicely.....
merdith6 is offline
Old 07-01-2011, 02:40 PM
Fortega95's Avatar
Finelly got it thanks for the help
