Jammin X1 - so close yet so far
#871
Hey guys i dont want to spend hours looking for the fix(if there is) for brakes locking up. i have polished and sanded the things that push the brakes and that didnt seem to help muck they are still sticking. I also removed the springs and made sure that the were 9.5 m form the base can somebody please help
#872
brake sticking solution
BRAKE STICKING PROBLEM
i think this is another perfect way other than the pull/push style
- brake cam and brake caliper have alot of gap. so dremel face of the plastic centre diff mounting where it meet the brake caliper. so that the brake cam face will be more nearer with the brake caliper.
- put shim/spacer/washer (same thick with the disc brake) between brake caliper on one side where the brake cam push. dont use the spring. this way will make only the other side of the brake caliper moving when on braking.
the brake cam only turning a very little to push the brake caliper and can prevent it from sticking
#873
Anyone else think that the Jammin shocks are a pain to rebuild correctly? I seem to be having a hard time bleeding them and getting both sides consistant. Any tips? What would be a better shock to use that would fit on the Jammin if these shocks just aren't as good as the others?
#874
brakes
check the ofna board under jammin.there are several threads there from some of us who had the same problem.
#875
brakes
i run the special brakes from rcmart.com.they work awesome.(prt#js08)
#876
have you guys seen the rc car action, the jammin x1cr got second in there buggy test, above the mugen mbx5 prospect and the xray, congrats, the only thing that beat it was the 777
#877
#879
Extreme RC, of course the SP1 was gonna win thats a given
#880
ya my bad, xtreme rc.
#881
Richclo get you some Mugen bladders,They last a LONGGGGGGGG time!
#882
but mine using mugen bladder, its really veryyy shorrrtttt life simply same as the standard one. it also pop off very easily
#883
Which Protoform bodies are fit for this car?
#884
Here's X1CR pictures...
#885
daniz,
What brake set up are you using? Can you give me the part numbers needed for this modification? Thanks bro.
Hey anybody else hear about Jammin releasing an updated kit soon? Xtreme R/C mentioned it in there cage match review in the current isssue. Just wondering if they were going to release an update package for us who already have the buggy.
Kit came together nicely for those who asked earlier when I bought it. Still have not decided what engine to drop in yet.
Does anyone have any experience with the Torsen diffs? I was thinking about adding one to only the front of the car.
Later
Brady
Later
Brady
