Jammin X1 - so close yet so far
#4066
I'd use the $130.00 plus to buy the new ring & pinion gears!!
#4067
I was bashing My Jammin buggy very hard the other day and on tear down i found that both of the t-bolts in the bottom holes of the knuckles were broken.
I've had this buggy of over 1 1/2 years and have not had this happen before, has anyone else seen it happen?
#4069
setup question
Ok guys i need some things cleared up on shock oil. If i run a heavier weight in the front than rear say 60 wt and 40wt how would that change the handling of the car instead of having 40wt in the front and 60wt in the rear?
#4070
you will have much lesser steering
and understeer at all speeds
#4071
You always want a bit denser in front , say 60 vs 50 rear, 50/40, 55/50.... or similar. A little bit harder in the rear is supposed to make it very stable, but I think also that it will understeer.
#4074
Well, here you have some pics of my Hyper ST Truggy during this last weekend, broke inn the engine and wow, very satisfied with the track test, the track its grass based and very bumpy and it was like seen a spider run, the tires moved a lot sucking the track while the chassis stayed low and very planted, loved it !, this weekend have my first race on the same track with the truggy, lets see what haoppen. The paint was done by a friend who always see how my 7 years old doughter go with me to the track and she help me a lot so he painted the body for her lol !!! ... :
cya !!
cya !!
#4076
Guys,
Im getting serious wearing on the pin areas, both front upper and lower sections and rear lower sections ... any special tip to solve this ?, King Heads have that parts with small set screws in order to, in theory, not get wear on those areas ... are KHZ good enough ?, any othe mod tip ?
I discovered this because my buggy wanted to fly yesterday during racing with the flapping movement of the lower arms lol! due to play on the pins, but discovered that the plastic parts are OK, it was the aluminum parts which wear out.
thanks,
thanks,
#4078
Pics
Cody
Do you have any pics of anything New that you can post
#4079
Guys,
thanks,
thanks,
