Jammin X1 - so close yet so far >
Old 07-23-2007, 02:46 PM
  #3736
xlgraphicspro's Avatar
So, has there been any talk about Jammin Producing an updated car, or even a new design? I know If they were, I'd probably have seen Taylor james driving it by now. I just know that this car has been out almost 3 years now, and with competition getting thicker every day, I think it's about time a new one!
xlgraphicspro is offline
Old 07-23-2007, 03:10 PM
  #3737
AZRCaddict's Avatar
I think they haven't because they are updating and releasing new parts all the time. I could see them selling it a whole updated car or maybe an updated conversion kit that would have all the new parts for current X1 owners.
AZRCaddict is offline
Old 07-23-2007, 04:52 PM
  #3738
prphze's Avatar
Trader Rating: 11 (100%+)
Do you really need to make the car better? The car is still one of the fastest out there. I would like to see minor changes but nothing to dramatic.
prphze is offline
Old 07-23-2007, 05:12 PM
  #3739
macnkitty2002's Avatar
Kyosho has been doing this with their buggies for a long time. the 777 series in particular.
macnkitty2002 is offline
Old 07-23-2007, 06:12 PM
  #3740
prphze's Avatar
Cool
Maybe we will get lucky and thats what they will do.
prphze is offline
Old 07-23-2007, 07:34 PM
  #3741
Panther's Avatar
There is nothing wrong with the current platform. Chad, Taylor, Gary Guest and Matt Gosch were all running the BIG bore shocks (similar to Losi) at the ROAR Nats. Shorter arms with a wider pivot point. Chad ran the current car at the 2006 Worlds, I can't see them running the same one at the 08 Worlds. Kyosho and Mugen have both stated that they are coming out with a new car. It would be nice if they'd offer a retrofit kit for all of us, but by the time the new kit comes out, a majority of us will need a new one anyways.
Here are some pics Mike Czech took at the Nats:
Panther is offline
Old 07-23-2007, 09:16 PM
  #3742
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Takt
I lock tite"d" the crap out of it, and still came out. Lock tite had the screw stuck in the collar though.
Thinking about changing back to the bolts come up through the hub and putting a nut on the end. Instead of my current threading a screw into the hub.
somebody did a switcharoo on ya, that type of hub isnt the jammin design, it sounds like the old 9.5 hubs....
Jason Halvorson is offline
Old 07-24-2007, 06:14 AM
  #3743
Takt's Avatar
Trader Rating: 15 (100%+)
Thanks ... that is what I was afraid of.
So what should I go to? My manual shows a "stud" that comes up out of the hub and a nut on it. Is that the way to go? Or is there an aftermarket part I should look at?
Takt is offline
Old 07-24-2007, 06:46 AM
  #3744
AZRCaddict's Avatar
The FTE knuckled with stud and nut works perfect. Havent had one loosen on me ever.
Old 07-24-2007, 07:49 AM
  #3745
prphze's Avatar
Panther , did you see this car in person? Looks like it's got different shock towers, shorter arms, and different shocks. Just wondering if you noticed any other differences?
prphze is offline
Old 07-24-2007, 02:54 PM
  #3746
AZRCaddict's Avatar
The pictures were taken by Mike Czech.
And everything looks smaller because the shocks are ginormous!
Old 07-24-2007, 09:02 PM
  #3747
your gonna have to go back to the jammin hub that works with the king pin (stud)....the hubs you have now doent work with king pins, cause there is no notch on the inside of the hub for the king pin to fit into....i use the king headz cnc steering hubs and have had no problems what so ever, and they are a bit cheaper than the jammin cnc hubs...
Old 07-25-2007, 03:41 AM
  #3748
CRASH's Avatar
Trader Rating: 26 (100%+)
Has anyone one here drilled the 7th hole in their rear shock tower?
Also, does it really make that big of difference?
Thanks,
CRASH is offline
Old 07-25-2007, 05:58 AM
  #3749
prphze's Avatar
Smile
Thanks,
I run the King Headz tower, and it already has the hole. I like it, and that's where I will usually run it. But like anything it 's not always the best spot, depending on track and track conditions.
prphze is offline
Old 07-25-2007, 05:13 PM
  #3750
i also run the king headz rear tower and use the 7th hole most of the time....
