Hyperion EOS0610i Duo II problems setup Help!!!
Hello There,
I just picked up a Hyperion Hyperion EOS0610i Duo II w version 5 firmware. im using it for 1c 1/12th 17.5
The problem im having is when the charging is done my cells voltage in the pack is 4.11- 4.15 volts on a volt meter
But when i charge the same 1c pack on my Competition Electronics GFX my pack has 4.20-4.23 on a volt meter and feels like it has more punch on this charger.
Im aware of the roar rule on the volts in the pack. on The Hyperion there is a setting in there to turn up the voltlage to the pack i even cranked in to the maxx just to see and my packs still come off a 4.11-4.15 on the Hyperion
The packs are fine when charged on the GFX but they feel flat on the Hyperion.is there something wrong with the Hyperion or can some one give me a setup for 1c 1/12th?
any help would be appreciated.
On the Hyperion it shows 4.19 but when I use the volt meter right after it charges it reads 4.11-4.15
The GFX reads 4.20-4.23 and on the volt meter it's reads
4.20-4.23
Any ideas?
4.20-4.23
Any ideas?
I find the same issue with mine. I just set the cutoff 0.02V higher and this will end up with around 4.2-4.17V after the battery been disconnect from the charger.
