Which tire remove method won't harm the foam and tires?
Brand new Xacto knife and carefully slice away the tire right at the rim. No heat or chemicals to affect the volitiales in the rubber.
Supposedly the acetone fumes are what softens the CA glue, so you don't have to submerse the tires to remove them (which ruins Losi tires, not so bad with Prolines). I've heard that you can get a sealable container and suspend the tire over a pool of acetone and it will debond the glue. I don't know if this take longer, or hurts molded CC foams. Not sure if it is any easier on the tires but it sounds like it would be.
They also sell CA debonder at hobby shops but that might hurt the tires.
Baking destroys AKA foams. They shrivel up and go flat.
Suspend them in a sealed bucket with acetone for 24 hours. The fumes will soften the glue so you can peal off the tread. Open cell foams don't like this method and some 1/10 JC tires don't like it either. But I have unglued and remounted many tires this way. Some three times and it has only killed one set of open cell foams. Best method out there. Oh and all done with the same acetone I bought 1.5 years ago for $10.
Some times when you screw up, you screw up.
