Yokomo B-MAX2 buggy thread
#136
Cheers
#137
Stumbled over something on Youtube - looking familiar?!
Cheers
#139
Any rear pin style wheel will fit, but front B4 won't quite fit as the yokomo bearing is slightly bigger on the OD. If your good enough with a dremel, you can take a poofteenth out of all your B4 hubs if you don't want to use them again with your AE cars. The AE bearing and wheel may fit, but I doubt it, as metric vs imperial.
Cheers
Cheers
#140
Yokomo offers AE front wheel axles for imperial bearings as an option part. (B2-010FI)
#143
#144
Ran 2WD stock on weekend, and pulled 5 podiums and managed a 2nd overall for the event. Pretty happy with the car so far. A few little pre-race issues, both front axle grub screws hadnt been tightened enough, and had both wheels leave the car on separate occasions. Lucky i had a few practice laps to begin with!
Car ran faultless all day! Time to dust it off and check over for maintenance.
Cheers
Cheers
#145
You could grind a little recess in the pin so that you can tighten the grub screw a little more.
#146
Fixed the slipping problem. Seems the spring wasn't compressing fully in the ball diff. Undone and retightened, slipper nut now 2 threads deep, set perfectly now.
Cheers
Cheers
#147
Cheers
