3 racing new F1
#4051
#4053
FGX Bendage
Ran my FGX/EXO/IFS acouple of time now and I'm bending the lower A-Arm ball studs. The ones that mount the inner piviots. The plastic adjustment bushiings and the piece them mount in are not breaking but the studs are bending. I know I shouldn't hit the boards but the stock front end and my other cars don't have problems with my driving, at lest not as mouch!
Are there stronger 4.8mm ball studs or is there another way to beef this up? Car seems to run ok with the stock froint suspension, I'm slow but it is fun to drive!!
#4054
@aarcobra,
I was looking on the TQRCRacing site and they sell 4.8mm aluminum balls that are threaded all of the way through, so you can use steel or whatever other material to affix them to the chassis.
http://www.tqrcracing.com/shop/produ....asp?p_id=2104
Scott
Scott
#4055
Posted on 3racing facebook but I'll ask you guys too, anyone know if the RIDE preglued R1 front and rears fit the F113?
Also the space for the ESC looks pretty tight, anyone know if a Reventon Pro with a fan installed will fit in there?
#4056
Anyway, good luck in you search (From the manual, the Hex for rear wheels is 14mm on F113).
#4058
Thanks!
@aarcobra,
Scott
Scott
#4060
Can anybody share a base setup for mid grip asphalt.
Running blinky 21.5
Exoteck chassis, alloy bulkheads, exoteck top and bottom front arms,
Shimizu tyres
What springs and shock oil?
What camber,caster and toe
Cheers
Running blinky 21.5
Shimizu tyres
Cheers
#4061
ChrisK,
Biggest factor is tyre choice. My previously used setups at WSRC , were polar opposites.
Use Shimizu grooved tyres : tune steering out
Use Ride slicks : tune to maximise steering
For Ride : I used stiffest rear springs and kit diff oil in rear shocks / 2 hole pistons
2* rear toe for happy medium. Max caster, 2 or 3* camber plate
#4062
Thanks for the tips
#4064
nice looking jordan! seems to be a popular livery these days, although im not sure coulthard would race for eddie jordan ha
#4065
Thanks I went for something bright as we race at night, I like the red bull scheme but to dark under lights.
