Team Losi JRXS
Originally Posted by CaseyP
Thanks (as Feles would say) FiliPOW
CaseyP--Also, several people have tried and loved the Keith B. set-up. Its on page 351 of this thread. Good Luck and let us know how it goes.
Brant
Originally Posted by T. Hodge
You have to run for us to get royalty checks
OOOOOHHHHHH........Thats gonna leave a mark!
Brant
Team EAM
Originally Posted by POOKYT
Race report from today.
I ran the first half battery with rear high diff. and the car was pretty loose in the rear like normal at our track. The track tightens up as the day goes on. I stepped back into my pits and rolled the diff. into the low position. Put the car back on the track and voila!!!! The rear end was as quick to roll around the turns but it was consistant and very much under control. I only needed to raise the rear inner camber location to dial it just perfect. The car was a little twitchy as all of the things I had done to gain steering over the past three races were still in the front. Remember I found a broken LCD pin in my right front drive this week and replaced it. That was the source of my slight push the past 3 weekends. I raised the front camber links to the top hole with my JR. camber link and the car was great. The only thing I wanted to try and didn't was to put back in my 6 deg. carriers as I think the 4 deg. ones were a tiny bit twitchy still. Qualified 2nd for the main( ran an old set of tires too long during qualifiers) and got the inside hole shot to never look back! I finished the 5 mins. .6 seconds away from lapping second place who is my X-Ray arch rival!!!! Also, the car ran the fastest lap of the day by 3 tenths. A great day was made perfect after I had just finished behind him and he immediately stepped back and asked me" Man!!!! What did you do to that car???!!!". I just smiled and told him I put on new tires for the main. LMAO I hope this helps you guys
Brant
Brant
Actually last year I didnt have to work to hard at it....Your radio did most of the work for me
EA
Oh Crap!!!!!
Note to self..........Don't make the motor man mad!!!! LMAO
Yo man! We better get our stuff together. DC is bringin some heat this year!! Can't go down like Dat!!!!
Brant
Brant
Oh......and Pooky has a new radio this year!!!
11 yrs on the old 756 was just too much I guess! LOL
Brant
Brant
Ok, I've been messing around trying to set up like the Numan setup - just a couple of dumbass questions....
Drilled #56 pistons - what size are they drilled??
BK brackets - am I supposed to mount the shocks to the extra hole in the new arms??
Cheers guys!
Cheers guys!
Cheers guys!
Cheers guys!
YOu can buy #56 pistons frm Losi, but a #56 is an actual drill bit (called obviousely enough numbered drill bits).
Yes-the new arms have the BK bracket position molded in. Its the one outside and up.
Thanks Ray - I got me some #56 pistons, but thought they still needed drilling (coulda been a cheapskate & drilled the old ones instead!!)
Thanks Ray - I got me some #56 pistons, but thought they still needed drilling (coulda been a cheapskate instead!!)
Sometimes team guys will drill a #56 piston with a #56 drill bit. Sometimes the molds are just a tick off. Thats getting pretty darn particular, not that a pro driver couldnt feel it.
and of course sometimes you drill out say a #60 piston with a #56 bit just because you dont own or cannot get a #56 while at the track like we did for my buddy at last years Champs.
Ray
Brant
Brant
Originally Posted by GroffBall
Those old 756s were great radios though I used one from 1995 until 2004. The steering literally wore out it wouldn't turn right anymore
LOL Same here! I had mine from '95 untill this past April. I let my son use it and he broke the steering 3 weeks ago!! LOL A Lot of memories in that old transmitter!
Brant
Cheers guys!
Cheers guys!
I know someone has probably talked about it recently, but I'm too occupied with other things at the moment to go dig in this thread...
Has anyone ever used the Numan setup on carpet with rubber tires? Is the preferred rubber setup very far from the asphalt setup?
POOKYT actually referred me to the Numan setup for carpet. It works great! I have read on this thread and at jrxs.com about others who have had great success with it. I think it's a great starting point.
Yup......it seems to be the starting point on carpet with rubber just like asphalt.
Brant
