Team Losi JRXS
R/C Tech Elite Member
Originally Posted by FBJ's RDX
Hi Randy, thanks for the tip. The reason why I asked about the insert is because an indoor asphalt track in my area just opened and the asphalt is very smooth. I ran my Losi last saturday and my car would push horribly on-power after 3 laps. I think I am having tire insert selection issues. The tires we always use are Sorex 36R, rims used where speedmind dish and for the inserts, I used a speedmind medium standard profile (more full, no airgap). Since the asphalt is so smooth, my tires would still be shiny after 2 packs of batts. What sort of insert should I use for this kind of track? Should I go for the ones that has maximum airgap with very stiff rims like tamiya and much more? Btw, how is the rear motor JRXS compared to the front motor? Is it going to be released soon? Thank you for your help.
Sonny
Sonny
The rear motor car is working great so far, but I definately wouldn't get rid of the front motor cars yet, they are still very capable of winning. No word on the release of the rear motor car, I havent asked or been told..
Originally Posted by JRX-S Bill
Todd and Team Losi have been at Stockton testing and practicing for the past few days. Should be arriving at his home this evening and be back at Losi in the morning.
As Brant says, "Give him a hollar" via PM.
I was wondering if anyone has had any probs with the alum. pivot blocks.
apparentely I got a defective one, 0 degree. one of the holes that the suspension balls fit into is too small, while the other side fits perfect?
Contact Todd Hodge at Losi.
I assume that you mean graphite pivot blocks. Never saw any aluminum ones come available to other than Team Losi drivers.
Hi JRXS Bill
The Rear hubs I am running are the 1 degree Offset hubs which with the 1 degree pivot mount give me 2 degrees rear toe. I have reset the pivot mount and roll center mount per Todd's instructions but the hubs he sent me were not 1 degree each. The left one was 1.5 to 2 and the angle was marked not with standard Losi surface print but a paint pen so not sure where these were from.
I was asking if the hubs are correct, what else can cause an error in angle. I did reset the screws and made sure they sat correctly.
Originally Posted by Randy Caster
No, trying to keep my car as close to Todd's as I can, his was super fast, and I dont want to stray too far from the good setup he found.
Cheers Malc THE CAN MAN
Originally Posted by Yeti35
The only corks I know of would be the one behind the wheel!!
winternats
i'm surprised that nobody posted that craig xavier just missed tq and the win in stock at the winternats at mimi's, in gaithersburg, this weekend. there was a reported 70 racers in stock sedan, including cuffs, schreffler, bradley, and ciccarello.
from what i understand, it's a fairly stock jrxs.
nice work, craig.
http://www.rctrack.com/Racing/Info/0306/03_05_06.htm
nice work, craig.
Tech Legend
Trader Rating: 51 (100%+)
Craigs JRX-S is almost always dialed!!!!!!!!!!! His cars are alot more stock than most. He is fun to watch race and one of the nicest guys around. He does a great job for his sponsors.
It would be awsome if Craig could post his setup or someone could do it for him!
Originally Posted by TheCoolCanFanMan
Randy, what is his/yours set up please
They both have the rear motored cars.
Thanks guys, the race at Mimi's was extremely tight, especially the main where I finished just over 2 tenths behind Cuffs. I was on his bumper looking for a way by but he wasn't giving up an inch. I have to give it up to Jeff Cuffs as he drove a flawless race. However I did TQ the stock class and also finished 2nd in the 19T class to Mike Dunnigan, just 1 sec behind in another close race. The car was working great and carried lots of speed through the corners. I am running almost the same setup as I have posted before, I am now running the new arms and with these have changed the front springs to 30lbs. The only non stock part of my car is the rear shock tower mounted to the back of the front bulkhead. I cut off the camber link holes on the front shock tower and cut off the shock mount holes on the rear tower and just use the camber links from the rear tower. I used hole #7 for the front camber link.
Originally Posted by Rick Worth
You mean like these: https://www.ssl-stormerhobbies.com/c...=ns&pn=LOS9683
