Team Losi JRXS
Originally Posted by rcracingkid
Sure, new or old arms?
Here is my current setup, it worked very well at the Magma race, and is what i typically run at SouthShore.....its dialed in for mod or 19 turn, should be decent in stock also.
Dawgmeat, if you want an older setup with the normal arms i could post that also.
Originally Posted by dawgmeat
Thank I'll take both I'm buying the new arms this Friday what make the new ones better?
I felt the car was much more consisten with the new arms, maybe slightly more corner speed also, here is my old arm setup...from Cleveland.
Both of the setups i posted were done for mod, but when i drop a 19 or stock in the car it just feels even better then whet it was going fast.
OK-OK Brain Fart here!!!! Anybody have the part number for the brown diff grease handy??????????? I can't seem to locate it. Thanks fellas!
Brant
Parts Dept.
B-Main Motorsports
Brant
Parts Dept.
B-Main Motorsports
LOSA3012 Brown diff grease
Originally Posted by POOKYT
I'm going to the carpet this weekend too ya know!
Matt--I can't remember but does your set-up run the front camber mod as well as the new style arms? Hollar !!
Brant
Brant
layout
Does anybody have a pic of the wire layout using the Tekin ESC?
JRX-s spring chart
I had got another jrx-s and all the springs had no labels, I heard that there was a charge the told you what the were by yhr lenghs, does anyone have that chart?
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
right then here goes
ran my JRXS on carpet with rubber tyres
ran as kit setup apart from 35ilb springs front ,30ilb springs rear
car is fine but .5 sec of the pace per lap
70% steering lock car gets grip roll , if i have full lock inside front wheel lifts up ), get`s round okay with 70%
do i go harder on oil or springs or softer
we don`t have foams on our carpet or powerfull additives , we use odourless additive , which might not be as powerfull (grip terms) as your paragon etc you use over there
car is kit setup to the T ,no r/bars either
I would try some antidive in the front, it should help keep the car a little more flat, and lose a little steering. Lean your front shocks in also.
That helped me when i tried rubber on a rug.
Does anyone have the chart to tell what lb springs are by how thick they are?
anti dive ????
shim behind wishbone yes ???
i layed the front down grip roll was worse
then i stood front on outside hole made it to nervous from 1 corner to another
so ended back in middle hole again
Size / Coil - Comp./ Ratio
0.045 / 4 - 10.5
0.046 / 4 - 12.5
0.050 / 5 - 15
0.052 / 5 - 17.5
0.054 / 5 - 20
0.058 / 5 - 25
0.062 / 5 - 30
0.065 / 5 - 35
0.070 / 6 - 42.5
0.072 / 5 - 50
0.072 / 4 - 60
0.075 / 5 - 70
