Team Losi JRXS
#4546
Re: Asphalt Set-Up
Originally posted by J Tronzano
Been following this thread for two weeks now while waiting for my JRXS. Well it finally arrived and based upon what I've been reading not a bit too soon. You guy's have been great, I learned a lot about what to expect when building the car and what not to do, so with the delay, I actually got a head start.
What i need some help with is a forgiving sert-up for asphalt. I say forgiving because I'm somewhat of a senior (63) and don't have the reaction response that you young dudes do.
Any help would be appreciated.
Just do the setup that is included in the back of the instructions. This is basically where the instructions lead you anyway. Only changes I have made are 17.5# rear springs and 60/40 on the shock oil.
Will know more after we hopefully meet up with Matt Francis this weekend at Speedworld.
Bill
#4547
Originally posted by Greg Sharpe
Here a shot of my chassis. Make note, the hole is no larger when viewed from the bottom. The angle I cut at starts at the rear of the hole and ends at the rear pivot mount screw hole. Easy!
I took my car apart for you. Remember that when I want naked pictures of your sister. Ok?
Thanks for the pic Greg. That's what I thought everyone meant, but I wanted to be sure before I started "hacking" away.
And Kevin, you may want to keep those pictures to yourself. I'd hate to see the person I'm gonna be harrassing for set up help incapacitated by a mad husband or fiance! j/k
So now that we've busted out the "your sister" jokes, when do the "yo momma" jokes start?
#4548
Re: Asphalt Set-Up
#4549
Re: I got a chance to look at the new Losi shocks....
Originally posted by RCknight
and all I can say is wow! They are smooth and I like the detail Losi has put into them. I love perfection in every little detail.
#4550
Re: Todd, RBLove, Ray or Anyone
Originally posted by CRASH
How far out do you have to space the front shocks top and bottom to run the number 1 hole inside on the tower? So that it does not rub.
Thanks,
Thanks,
#4551
Originally posted by Tony Szep
When will all of the option parts be out?
#4554
Asphalt Set-Up
Thanks to Wannabee, JRX-S Bill and special thanks to Mr Hodgimoto for the quick response.
I start building tomorrow, probably be asking for some building advice as we go along, although much of the issues have been covered already.
I'll let you know how my first run goes, probably won't be for a couple of weeks.
Thanks again
Thanks again
#4555
Re: Re: Asphalt Set-Up
Originally posted by JRX-S Bill
From another old dude (with essential tremor)...
Bill
Bill
#4556
hey guys... i have a question for you, it may be simple, you know something i overlooked in my sleep deprived state, but here is my question,
i am building the car, i am installing p.l's setup from clevland, it uses, the outer whole on the hub, and the inner lower hole of tower, i am also using bk bones(home made), here is the problem,
as i shorten the camber lind it seems that the cvd binds on the inner diff, not allowing me to get more than say +.5 of camber nad even at that the arm is bound....i am no newby, but this is a bit off....
mayby i ahould phone paul or todd and see if they had the problem.
matt
thanks, matt
matt
thanks, matt
#4558
Originally posted by rayhuang
matt-the rear hubs your usiing I bet arent off set hubs so they go in the outer holes on the arm. Now-Dont scream at me if you do have the offset hubs.
KE
